Oil Burner Help - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 06:11 PM   #1
Oil burner help
I recently aquired a house needing some attention,here is my first issue,the oil burner,It has a Aquastat protectorelay,,,it has a BLACK wire connected to a terminal marked ( B1 ) & a WHITE wire connected to terminal (B2) the burner has 2 wires one BLACK & one WHITE & the ignition has a BLUE WHITE wire & a WHITE wire my problem is I am not sure how to wire them all together any help would be appreciated
russell12 is offline   Reply With Quote
Old 01-08-2011, 06:48 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 332
Ayuh,... The Black wire from the control, 'n burner motor Black wire, 'n the the Blue stripe wire all get tied together with a wirenut...
Then All the Whites together...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
russell12 (01-08-2011)
monitor heater repair help speakers3 HVAC 16 01-18-2015 05:00 AM
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 06:58 PM
furnace burner problem brent h HVAC 2 01-11-2010 08:50 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 02:37 PM
