Oil Burner - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 10:49 AM   #1
Oil Burner
I have an oil burner that I keep having to bleed every time to get it to run. The nozzle is new and so is the filter, before I go and replace the pump is there something else I could do? Do the pumps have an internal check valve in them that could be gummed up?
cooper90 is offline   Reply With Quote
Old 12-09-2012, 08:54 AM   #2
You are not giving to much information.
Is your oil tank buried, or above ground.
There can be a hole if the lines run underground from the tank. This has happen on more than one occasion and the customer said he had checked them no leaks. Guess what they were leaking and he had oil leaking out underground. He changed every part even a new oil burner assembly before he did a good thorough check of his lines. When he found the leak and repaired it no more problems.
There is a screen in the oil pump that can get clogged. I once found part of the oil filter in the oil pump.
Check your pressures at the pump about 100PSIG
Hope this can lead you in the right direction.
* Of course you may need a HVC tech to do these checks for safety concerns.
oncall is offline   Reply With Quote
monitor heater repair help speakers3 HVAC 16 01-18-2015 05:00 AM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 10:53 AM
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 06:58 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 02:37 PM
