Old 11-18-2012, 01:59 PM   #1
Oil burner
Everytime oil burner shuts down, about one minute later there is a one(1) second bang coming from the unit. It's been doing this for months now.
TOM113910 is offline   Reply With Quote
Old 11-18-2012, 04:31 PM   #2
Hvac Pro
Oil burner
Probably the nozzle is dripping oil into the chamber and re-igniting later. BAD scenario and can be dangerous. Get it properly serviced and setup by a Pro who uses a combustion analyzer, not eyeballing the flame.
Old 11-19-2012, 07:15 AM   #3
An old Tradesmen
Oil burner
Or it could be the duct work contracting from cooling down. if your system is ho air, have you changed the air filter lately.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (11-19-2012)
Old 11-19-2012, 10:37 AM   #4
Oil burner
You have to determine if it is actually after the burner shuts off OR if it is after the forced air fan shuts off. If after circulating fan then it is the ductwork ..likely dirty filter or AC Coil causing excessive pressure differential across main plenum thereby sucking it in when fan on then it releases when fan tuns off making the banging noise. If after burner shuts off...this is a serious problem but, not expensive to fix..burner must be cleaned, inspected and combustion set up by a pro.
Please let us know the outcome as we are always interested in knowing.
techpappy is offline   Reply With Quote
monitor heater repair help speakers3 HVAC 13 11-25-2012 10:44 PM
Sears GAs furnace issue with burner running too long dmanmtl HVAC 17 01-03-2012 10:41 PM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 10:53 AM
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 06:58 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 02:37 PM
