Oil Burner - HVAC - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 06:40 PM   #1
oil burner
heavy oil smell coming from my oil burner when it fires up
billc2012 is offline   Reply With Quote
Old 04-12-2012, 01:50 AM   #2
REP
You shouldn't be smelling oil unless there is a leak.Since you didn't say you are seeing a leak then I can only assume that the leak is internal.
That could be a loose nozzle or a pump that has lost its seal.
It could also indicate that the combustion chamber has collapsed and you are getting an incomplete burn.
REP is offline   Reply With Quote
Old 07-26-2012, 01:02 AM   #3
Rewards Points: 610
Observe burner at start up. There may be a delayed ignition causing a puff of smoke to leak out of the observation port or the vent/flue. It will smell like soot though not strong oil odor. Remove burner to check for leaky lines/nozzle or incorrect settings (sometimes the air diffuser may be too far ahead of the nozzle which can cause the oil spray to impinge on the diffuser as well. Do internet search to find burner, diffuser,nozzle and electrode settings for your make and model furnace Manufacturer's Technical Bulletins or Start up instruction manual. BE CAREFUL NOT ALLOW TOO MANY STARTS WHICH COULD ALLOW EXCESS OIL BUILD UP IN COMBUSTION CHAMBER AND CAUSE UNCONTROLLABLE BURNING/SMOKE ETC. Best to have serviced by oil burner contractor if you are not sure. Could be DANGEROUS and cause heavy smoke damage/fire. It is difficult to tell if absorbed into refractory because it can be soaked in and remain dry on surface.
techpappy is offline   Reply With Quote
monitor heater repair help speakers3 HVAC 16 01-18-2015 05:00 AM
Sears GAs furnace issue with burner running too long dmanmtl HVAC 17 01-03-2012 10:41 PM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 10:53 AM
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 06:58 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 02:37 PM
