Oil Boiler Will Not Fire - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 07:15 PM   #16
It got a new 1.50/80 nozzle, fuel filter, pump screen and electrode kit (all set to specs) really cleaned up the spray pattern.
flatlander745 is offline   Reply With Quote
Old 02-16-2010, 07:18 PM   #17
I was looking at the flame pattern in the box, alot cleaner than it was before. It was almost blinding before like the oil was coming out of a garden hose in a stream.
Old 02-16-2010, 07:18 PM   #18
An old Tradesmen
Rewards Points: 6,086
Originally Posted by yuri View Post
I ALWAYS put a new nozzle in every year with a maintenance check. Inexpensive part and the most critical part of the system.
In the old old days(8 bucks an hour labor charge, and I got paid 3 bucks an hour, woo hoo ). We use to clean nozzles as small as .85
And wonder why each year the boiler/furnace would be sooted up more then it was in the previous year.
A new nozzle every year saves far far more then it cost.
Old 02-16-2010, 07:23 PM   #19
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
After a few filthy-30F callbacks at night we change the nozzle every time. I wonder if there are stats as to how much a properly setup burner with a combustion analysis and barometric setup will save versus a visual setup. I am sure that with the outrageous price of oil it would more than pay for itself. If it ain't in writing homeowners won't believe it. The oil companies would like to keep that info private. Them Sheiks like their racing camels and Dubai Tower etc.
Old 02-16-2010, 07:39 PM   #20
An old Tradesmen
I use to have a paper on that years ago. No idea where it is now.
Several oil service trade groups/organizations(not oil providing companies) had done test on eye ball and combustion testing set up units. And had an average efficiency difference. I thnk it ws 6% min at season start up, and of course increased by the end of the year from soot build up on the eye ball systems.
Old 02-16-2010, 07:44 PM   #21
Hvac Pro
yuri's Avatar
3 Bucks an hour, wow you must be "experienced". LOL. I started at $13, charged about $40. I hope you gave yourself a raise. My "eyeballin" ain't as accurate as it used to be so we would be out by at least 10%.
Fits right in with my siggy below.
Old 02-16-2010, 07:51 PM   #22
An old Tradesmen
LOL... 3 bucks an hour was a lot back in 1975 for an xx year old
Old 02-16-2010, 07:56 PM   #23
Hvac Pro
yuri's Avatar
My first real job was "honorable dishwashah" at a Chinese restaurant. Great place to get started, free food, cute waitresses, except for the nightly ritual of cleaning the baked on rice in the huge pots, ugh.
Old 02-16-2010, 08:01 PM   #24
Licensed Master Plumber
OK so now it's all back together and running. What is the
Over fire draft
Draft at the breech
O/2 or CO/2 reading
Excess air in %
How about the smoke reading is it a trace or is it higher?
What is the flue gas temperature at the breech?
There is a whole lot more to setting up an oil burner than getting the right nozzle and the electrodes set in there correctly. Any one of the above settings are off and you could be either throwing money up the flue, rapidly sooting up the boiler or producing carbon monoxide. Without a combustion analyzer and the experience to operate it and make the proper settings, fiddling with an oil (or gas) burner can have some disastrous results.
Now a buddy of mine would say that that was an anti DIY post, but believe me, I care more about your and your family's safety than I do about being politically correct. Get a technician out to check your work post haste.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-17-2010, 01:01 PM   #25
Over fire draft
Draft at the breech
O/2 or CO/2 reading
Excess air in %
I appreciate your concern NH; my buddy has a meter that is getting recalibrated and he should have it back today or tomorrow to check readings.
Indoor Boiler Question AndrewF HVAC 134 05-13-2011 06:15 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 07:28 PM
Boiler one zone call heat but not fire up Ballastar Plumbing 6 02-13-2010 12:17 AM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 05:21 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 09:38 PM
