Oil Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2014, 08:06 AM   #1
Rewards Points: 109
oil boiler
Pipe freeze and burst on the second floor. Fixed it and burst again now in boiler room. I turned the system off and shut off water to the unit. Afraid it might burst in the ground. What you suggest? I would like to get it up and running...no heat in the house. Baseboard throughout the house, no basement.
Tek1 is offline   Reply With Quote
Old 02-18-2014, 08:47 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,.... If you've got multiple pipe Bursts from freezin', ya gotta drain the system, repair All the busted pipes, refill the system, check for more leaks, 'n then when All the pipes are fixed, 'n it's been refilled to 12psi,....
Fire it up,...
Bondo is online now   Reply With Quote
Old 02-18-2014, 09:57 AM   #3
Rewards Points: 109
Fire it up,...
Would not drain completely, I am thinking ice blocking it somewhere.
Old 02-18-2014, 10:01 AM   #4
Rewards Points: 109
I drained the system the first time and pipe burst in the boiler room couple minutes after I fired up.
Old 02-18-2014, 11:00 AM   #5
Rewards Points: 150
was the heat shut off completely? Is that why it got cold enough in the boiler room to freeze the pipe there? If thats the case drain system down cap off feed and return and verify boiler hasn't cracked by putting water pressure back into boiler. make sure you look inside at area around combustion chamber.
hpyjack2013 is offline   Reply With Quote
Old 02-18-2014, 11:13 AM   #6
Rewards Points: 109
Yes...She ran out of oil.
Old 02-18-2014, 11:20 AM   #7
Rewards Points: 150
start with the boiler make sure it can take 30lbs then fire it up and check again
Old 02-18-2014, 05:28 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
You are going to need to get some electric construction heaters in the basement and house and warm it up to at least 50 deg F. then check the boiler for leaks before going further into repairs.
Suspect Electric boiler causing brownout crankcase Electrical 4 11-06-2012 01:41 AM
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 06:10 AM
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
