Off Season Furnace Question Rheem - HVAC - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 05:05 PM   #1
Rewards Points: 80
Off season furnace question Rheem
Rgpl10ebrmr furnace Criterion II plus LXE
Heat airflow adj switches 1and 2
If you adjust this to achieve mid rise +10, I assume that the ECM slows the cfm to create the additional temp rise?
If yes, do we know how much the loss in cfm will be? Not sure if I asked that right?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 07-30-2013, 06:09 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 92
not sure about that Rheem but with Lennox they have the airflow at the different dip switch settings in the install manual. they will give it to you but you must do a delta T heat rise temp to make sure it is not overheating. if not contact Rheem and I am sure they have in for their dealers or can get it for you in a pdf file.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (07-30-2013)
Old 07-30-2013, 06:58 PM   #3
Rewards Points: 80
Thanks yes reading in the book states "adj these switches 1 and 2 can vary the airflow to give a temp rise at mid point........."
I just wanted to make sure I understood that there would be less cfm, but warmer air out of the vents.
Old 07-30-2013, 07:51 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 92
Should Bee as the gas pressure/firing rate stays the same. You need to check the temp rise or it will blow the limit control and possibly damage the heat exchanger.
digitalplumber (07-30-2013)
Problem with Rheem Criterion Furnace sweetsue777 HVAC 3 03-10-2012 11:13 AM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Furnace intake noise question joeg679 HVAC 6 12-11-2009 12:03 PM
Electric Furnace question whatsthis HVAC 32 04-08-2009 07:39 AM
