Old 11-01-2009, 11:11 PM   #1
Default On/off fan delay settings?
I've set the HEAT-OFF delay to 100sec, was set 140 originally but blew a lot of extra cold air, did not touch the others they are set:
COOL-ON: 4 sec
HEAT-ON: 30 sec
This is a Honeywell ST9120C fan controller, are those the correct settings for ON?
ls3c6 is offline   Reply With Quote
Old 11-03-2009, 12:33 AM   #2
bump, no guidelines?
Old 11-03-2009, 08:38 PM   #3
nobody understand the question???
Old 11-03-2009, 09:16 PM   #4
An old Tradesmen
The cool on delay os set to your areas climate.
If your in a high humidity area. 4 sec is too short.
Heat delay, set it to where the air comes out warm but not hot at first.
There is no one right setting.
Old 11-03-2009, 09:17 PM   #5
I live in west michigan, I wouldn't say our summers are any more than mild... the heat-on delays are 4 or 30 sec, currently 30 sec and haven't tried 4 sec, the heat comes out pretty hot initially (and around 110f at the vents)
Old 11-03-2009, 09:19 PM   #6
An old Tradesmen
4 would normally be too short.
Old 11-03-2009, 09:22 PM   #7
is that also too short for cool-on? see prevoius owner had a furance company replace the timer, when i moved in i figured out the reason it went BAD was because the drip tube needed cleaned and the timer board was getting wet... so they had set many things wrong, including the COOL FAN TEMP TO MEDIUM, set that to high and it worked much better... now i'm tackling these delay settings
currently the heat terminal is set to MEDIUM-LOW and produces about +50-55f at the vents, any reason I should go to MEDIUM?
Old 11-04-2009, 05:56 AM   #8
An old Tradesmen
No. thats a good temp rise. Setting it lower will make the air warmer. But, you don't want it to be hotter then that. So leave it as is. Or it won't leave room for the filter to get dirty.
Old 11-04-2009, 10:20 AM   #9
i'm asking if there's any benefit in going from the existing MEDIUM-LOW to a slightly higher fan speed of MEDIUM?
Old 11-04-2009, 12:04 PM   #10
An old Tradesmen
Nope.
Just makes the air cooler coming out of the registers.
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip we will be showing you step one for painting our ceiling. Before we get started painting our ceiling we first need to remove anything that is on the ceiling. This includes our ventilation... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be installing our ceiling fan. Sine this room is going to be for a girl, we've purchased this ceiling fan which is a more feminine. Now our ceiling fan is a 44" fan, now you don't want... Read More »
Tips for Painting a Ceiling
Tips for Painting a Ceiling by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip we'll be painting our ceiling. Before painting our ceiling we need to remove any object on the ceiling this includes smoked detectors, any types of hooks that might be in the ceiling. In... Read More »
How to Pick Ceiling Fans
How to Pick Ceiling Fans by Expert Village
Hello! My name is Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, this is how to install a ceiling fan. Some of the things that you need to consider before selecting a new fan for your home are fan size height from the ceiling, blades... Read More »
Hi I'm Mark Sullivan for Expert Village. Today we are going to learn how to install a ceiling fan in your home. Today we are going to learn how to install a ceiling fan in your home. We have a standard hundred and ten volt lighting reciprocal here. But... Read More »
Aux and Emergency CPH settings indvid HVAC 2 03-02-2009 05:31 PM
Vista display settings not holding. Kap PC Repairs & Upgrades 6 01-09-2009 03:05 PM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 05:39 AM
Delay on Break timers rjbaiad HVAC 6 09-24-2008 07:17 AM
Rheem IIBC Fan Speed Switch Settings budkocher HVAC 1 07-16-2008 05:32 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
