Odd Thermostat "Fan On" Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 03-24-2010, 06:43 PM   #1
Rewards Points: 150
Question
Odd Thermostat "Fan On" issue
Here's my setup... Hunter 44550 thermostat wired to new Dayton (Luxaire) furnace. All works fine. If I set the fan switch from "auto" to on, the fan comes on... no problem there. However, if I short R & G (to turn on fan from separate control), the A/C condenser kicks on, even though it is in Heat mode. It will only do this if the thermostat is connected. With the thermostat disconnected, only the fan comes on. It is sort of like the signal is backfeeding through the thermostat and turning on the A/C.
Reason for doing this... the thermostat does not have an intermittent fan run schedule, and I want to run the fan once every hour for 15 minutes, to normalize temps through the house. I wanted to connect an X-10 module on a schedule to do this. So far, X-10 is not the issue, not even in the picture yet.
Is there a way to isolate the signal with the current setup? I was thinking some sort of diode, but that is more for DC voltage, and we are talking about AC here. Also, I am afraid that if I spend the money on a new thermostat, I am only going to end up with the same problem, and lose the one feature I like about the Hunter (run-time timer- shows how long the system was heating/cooling for the day).
I know I can do all of this plus more with a new thermostat from BayWeb, but $220 is a bit more than I can spend right now.
Thoughts and ideas appreciated.
TJ
TJ_in_IL is offline   Reply With Quote
Old 03-24-2010, 07:10 PM   #2
Rewards Points: 150
Additional info...
The thermostat is wired 4- wire, with a jumper for RH and RC. I removed the jumper from the RC (to isolate the 24vac from the cool side), but still the same. With the thermostat connected, jumping RH and G at the control board kicks the contactor.
Old 03-24-2010, 07:13 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
If you send a signal backwards from the furnace to G on the tstat it will internally hit Y in the tstat and start the A/C. In the old days the tstat energized G to start the fan with A/C and Y at the same time so it can still happen as the tstat companies have to build them that way for the existing older units. New furnaces energize the cooling fan with the Y signal at the circuit board and G can be used for low speed operation. Long story short, you cannot have more than one wire on G at the board at ANY time or use it for more than one purpose.
Read this:Unexpected wiring found on existing thermostat
Old 03-24-2010, 07:17 PM   #4
Rewards Points: 150
Energizing G at the thermostat kicks the fan on "high" or the cool speed. When the unit calls for heat when the fan is in "on" mode, it will kick the fan to the lower speed.
Old 03-24-2010, 07:20 PM   #5
Hvac Pro
yuri's Avatar
The more expensive higher end models of some brands use the G for low speed (Lennox does) same principle about the backfeed for all brands. Not sure how yours is configured.
Old 03-24-2010, 07:24 PM   #6
Rewards Points: 150
Just tried this out, and seems to go along what you said.
I disconnected G from the thermostat, and tried jumping R & G at the control. Bingo! We have a winner. Fan comes on without also pulling in the contactor. So, as you said, "Long story short, you cannot have more than one wire on G at the board at ANY time or use it for more than one purpose."
Thanks for helping think this through Yuri. I guess I will have to disable the fan switch on the thermostat (disconnect the G), and only control the fan over-ride from the X-10.
TJ
Old 03-24-2010, 07:38 PM   #7
Hvac Pro
yuri's Avatar
Yep. This problem has been known for many years in Canada, read the other post. Lifebreath has built an extra circuit into their HRVs for this but not the tstat companies.
Old 03-30-2010, 09:27 PM   #8
Rewards Points: 150
Problem Solved
Well, I was able to solve the problem. All I did was wire in an isolation relay. Now I can connect my X10 relay to the R & G, and it does not back-feed to the Y, and turn on the A/C. And, it cost less than $10 for the solution!
I used a 4E658 from Grainger.
This may also be helpful to those up North, that need to wire in controls for a Bath or Range fan.
Here is a Schematic:
Old 03-30-2010, 09:59 PM   #9
Hvac Pro
yuri's Avatar
The diagram does not work from what I see as the coil needs to go to C etc. I can imagine what you did and I can use a R8222D relay to create special projects. We don't do a lot of that for liability reasons. Once you deviate from the UL and AGA/CGA rating/approval, problems can happen. Glad you got it working.
Old 03-30-2010, 10:05 PM   #10
Rewards Points: 150
Updated Image
WOW! I can't believe I did that! \Thanks for catching that.
Here is the correct version:
Thanks Yuri.
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Thermostat / Furnace issue Newbie5 HVAC 1 10-14-2009 06:25 PM
Thermostat Wiring issue swampdawg_101 HVAC 20 11-21-2008 12:01 PM
thermostat issue? e2fireman HVAC 9 06-29-2008 12:33 PM
