Old 06-30-2009, 10:48 AM   #1
Handi Man Services
Default Octopus Furnace Replacement
I am a newbie to this site and I like what I have read here. My son and I are looking very seriously to purchase an old home with gravity feed octopus furnaces (two). We are trying to estimate the cost to replace the furnaces and add central air. I will DIY all of the duct work and hire a licensed HVAC installer for the heat and air units. I completely understand the asbestos issues and can easily remove the old units. I am trying to get a better understanding of the duct work requirements. The heat ducts were placed on exterior walls, thank goodness for that. The return air ducts are on the first floor in the main living areas of the home. Can I use these return air ducts as is, or do I need to run new returns to the upstairs bedrooms?
Buseboyz is offline   Reply With Quote
Old 06-30-2009, 06:29 PM   #2
An old Tradesmen
Your going to wnt to add a high return to the upstairs.
Old 07-01-2009, 12:17 AM   #3
hvaclover's Avatar
When you say you understand the asbestos issue can i assume you are using a EPA certified asbestos remediation service?
Also Ann Arbor has a requirement that a licensed metal man install and pull permits on the duct system.
DIY one thing but this is a for profit project you are doing where a buyer or tenants are concerned and not done professionally you will be endangering their lives..
If you take short cuts and remove the asbestos your self, don't even think about it. You do not have the proper training or equipment. You have to provide a certificate from the EPA approved asbestos removal company before you can demo the gravity furnace Ann Arbor building department takes a dim view of non- permitted work.
Think about it. Somebody here might just be the mechanical inspector.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 07-01-2009, 04:09 PM   #4
Handi Man Services
Permits will positively be pulled and I would not even consider removal of the asbestos. The old furnace I can remove. Just wanted to get an idea if I need a return run up to the second floor. I am now sure I will need a return, which will run up to the attic (insulated in non living space) and use radial ducts to each bedroom thru the ceiling. Thanks for any and all replys
More On This Topic
You've finally booked that long European vacation you've been saving for, but you're not sure how to get around once you get there. A rental car may give you the most flexibility, but you don't have a European driver's license. Fortunately, all you need... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. In most cities, you'll be required to pull a permit, when finishing your basement. If you maintain open communications, with the city, they'll be able to... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Nebraska offers excellent game hunting, from bighorn sheep to elk and deer. Stalking through Nebraska's woodlands and open plains makes for an exciting hunting adventure, so follow a few steps to secure the correct hunting license for your trip. Read More »
You have decided to answer the call of the open road--on a motorcycle. Now you need to know how to get your permit so you can get out there and ride. Lucky for you, the process is pretty easy. Read More »
Advice needed. Complete Furnace & duct replacement - asbestos ductwrap (crawl space) vestaviascott HVAC 11 03-10-2009 07:40 PM
Replacement furnace, add AC coil now?? NJ user HVAC 5 02-05-2009 09:45 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
Furnace Replacement Options? Genhawk21 HVAC 5 01-11-2008 11:41 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
