Obsolete- Need Furnace Fan Control - HVAC - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 03:34 PM   #1
Rewards Points: 1,832
Obsolete- Need furnace fan control
Hello
Im looking for a replacement combination fan control and high limit for a gas furnace. The old ones plastic started to crack and will no longer shut off the blower. All elese is ok and works correct.
After trying to look for a new one I was not able to find a new one with the same part number as the old one. I was told there is a substitute to it, but I have no clue which is the correct limit as there seem to be hundreds of diferent kinds avalable.
The old limit has a model number of: L4064A2782-6-8630, has an insertion rod of 11 inches and says "Honeywell" on the cover.
Please let me know if more info is needed. Thanks
Jump-start is offline   Reply With Quote
Old 09-26-2012, 04:15 PM   #2
An old Tradesmen
Rewards Points: 6,568
How many wires in yours. is the limit circuit line or low voltage. Can't find your model listed. But should be able to determine which you need without too much trouble.
Old 09-26-2012, 05:04 PM   #3
biggles's Avatar
check out this site local Grainger has those Honeywells with the silver covers and that black disc that you set the temp.pins at http://bestbuyheatingandaircondition.../fan&limit.htm
Old 09-26-2012, 05:30 PM   #4
There are 3 wires leaving the control. The limit is line voltage and heads down to the control step down transformer. The heating delay connects to the blower. The set up is nearly identical to the circuit in the diagram on figure C except the jumper is not removed like in B.
Old 09-26-2012, 05:47 PM   #5
how
Rewards Points: 1,102
Post a picture of the old fan/ limit control!
how is online now   Reply With Quote
Old 09-26-2012, 06:04 PM   #6
An old Tradesmen
L4064b1451.
Old 09-26-2012, 06:16 PM   #7
how
1/2 of our furnaces still use this control but I live in an area that is weather gentle on furnaces. The L4064b1451 is a common stock part in our supply houses.
Old 09-26-2012, 07:04 PM   #8
I will try and get a pic tommorrow if I can, the limit is still inside the furnace. I have a Grainger account and plan on getting it from there. I looked at L4064b1451, and it's avalable
A guy at the supply house recommended this though:
http://www.grainger.com/Grainger/HON...820?Pid=search
What are your thoughts? What is the difference between the two?
Old 09-26-2012, 08:05 PM   #9
An old Tradesmen
That one will work too.
Old 09-26-2012, 08:32 PM   #10
Whats the difference though? Im just worried about the mounting holes being off. Is there any way I can compare the holes on the replacement limit before purchasing it?
Old 09-26-2012, 08:47 PM   #11
An old Tradesmen
The 2210 is an older version of the 1451, thats all.
Mount holes are the same.
Old 09-26-2012, 09:47 PM   #12
how
If all the holes don't line up (sometimes one or two won't), just drill a small pilot hole where you need it and use a sheet metal screw.
Remember to write down which wires go to the power/fan & limit slots of your old part so no mistakes happen with the re wiring.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace control board schematic rusty1 HVAC 2 07-17-2011 04:40 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Universal furnace control board Davidj0717 HVAC 1 10-14-2009 06:37 PM
heil gas furnace fan control shooter49 HVAC 1 10-24-2008 02:51 PM
