A.O Smith Universal Run Caps - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 08:35 AM   #1
HVAC Tech/ Browns Fan
A.O smith Universal run caps
We been using A.O smith Universal motors and it comes with Universal run cap. Do you guys use that or get a regular run cap the hp is asking for. I had seeing using the Universal run cap the amps are higher then regular run cap
Tator1076 is offline   Reply With Quote
Old 02-04-2012, 09:29 AM   #2
Not sure what you're speaking of tator. Have not seen a cap come in the box with a motor. Can you clarify?
The Following User Says Thank You to Marty S. For This Useful Post:
plummen (02-05-2012)
Old 02-04-2012, 11:17 AM   #3
We get them from Granger and it A.O smith motor that has 4 different hp as long you put right rating run cap. It comes with run cap that has 4 sets of rating.
Old 02-04-2012, 12:36 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
are those ratings stamped on the cap ie: 5 mfd/7.5 etc? If not I would stay with the one they supply as it is matched for that motor.
Old 02-05-2012, 12:12 AM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If its one of those big ol universal caps im thinking about theyre pretty pricey,maybe install a normal cap on there and save the universal one for an emergency
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
hvactech126 (02-05-2012)
Old 02-05-2012, 09:10 AM   #6
I know pros who use them as temporary replacements while a new cap is on order.
Other wise why not just keep a good supply of caps on hand? They are the least expensive of all the stock a pro carries,
hvac5646 is offline   Reply With Quote
Old 02-05-2012, 11:11 AM   #7
I have good supply of caps. Just when I get this motors they come with universal run caps. I guess you all had never came across this kind of universal a.o. smith motors.
El dorado wall caps arent sticking scotzilla General DIY Discussions 1 07-27-2011 10:40 AM
ao smith flammable vapor detector aosmithsicks Plumbing 2 06-10-2011 07:59 AM
a o smith thermocoupler replacement big mac 154 HVAC 2 10-29-2010 11:07 PM
Post caps marshallzulu Carpentry 0 10-09-2009 10:23 AM
