Old 10-29-2010, 06:32 PM   #1
a o smith thermocoupler replacement
I;m replacing the thermocoupler on my pro max water heater. However, the honeywell universal replacement doesn't match the existing one. the smith tc is actually two pieces, with what seems to be a sort of fuse between them. The replacement is a single copper line.
Can I just bypass this fuse contraption or do I need to buy an actual smith replacement. I saw something that ao smith knew there were problems with their tc
Thanks for a prompt reply. we need to take showers here!!
Dave
big mac 154 is offline   Reply With Quote
Old 10-29-2010, 06:43 PM   #2
Hvac Pro
Sometimes they make them with backwards or left hand threads and so that only theirs will fit. May have a fusible link which is required by UL and AGA codes so if you bypass it then you could be liable.
Old 10-29-2010, 11:07 PM   #3
HVAC / Plumbing
If that's the newer type wh with piezo ignitor. regular thermocouple won't work
kenmac is offline   Reply With Quote
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
Questions about finding replacement blower motor revg HVAC 3 02-14-2010 08:39 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 04:50 PM
