Old 02-01-2009, 09:55 PM   #1
Default Nozzles .559/.579
According to the information I have on my Miller Mobile Home furnace, it states that it is a .75--4.00 GPH. I went to the parts store for a .559 nozzle which they said they had in stock. When I got there they gave me a .579 and said they don't have the .559 anymore and to just set the distances in the electrodes and nozzle the same as for the .559.
While I was there a young contractor said to the clerk that the two nozzles are interchangable. He also mentioned that the only difference between the two is 2000ths. of an inch in the front of the nozzle, which is not much and won't make a difference.
He also said that .559 is a 55/90 and .579 is a 57/90. When I asked the clerk if the spray on the .579 nozzle is a 60 degree spray or a 90 degree spray he could not answer and no one else there couls tell me either.
From the information I have I gather that the Miller I have is a 60 degree spray.
Question?
Does anyone know what a 55/90 and a 57/90 means ?
Do the settings for the nozzle and electrodes change with a .579 ?
What degree/angle spray should I have a 60 or 90 ?
How far into the heat shield should I lock in the entire electrode unit ?
Determined.
Determined is offline   Reply With Quote
Old 02-01-2009, 11:44 PM   #2
An old Tradesmen
55x90 means .55 GPH, and a 90° spray angle.
.57x90 is .57 GPH, and 90° spray angle.
Electrodes get set flush with the face of the nozzle, and 7/16 above center of nozzle.
Old 02-02-2009, 06:04 PM   #3
Thank you beenthere
I will try the setting you mentioned.
Old 02-03-2009, 12:10 PM   #4
Thanks again Beenthere,
Settings were made at 3/16 between electrodes, 7/16 above center of nozzle and electrodes set flush with front of nozzle as best we could because of wear and too many times sanded or filed.
Working very good. Still a slight roar but heat is good.
More On This Topic
Discover Welding Sticks
Discover Welding Sticks by Expert Village
On behalf of Expert Village, I'm Terry and today I'm going to show you how to use a welder. This is a stick welder. This is the electrode. This is called the stinger and this is the grounding climber. I'm using an 8th inch rogner sew set. Right about 75... Read More »
Hi my name is Matthew Christian from Tampa, Florida and on behalf of Expert Village. Today we are going to talk about the proper use and maintenance of a pressure washer. Okay another item to be familiar with as part of your pressure washer is the wand... Read More »
Hello! My name is Mac. On behalf of expertvillage.com, I am here to continue our discussion about arc welding. We have been discussing shielded metal arc welding or stick welding. And now I would like to give you an overview of the welding electrodes... Read More »
I'm Matt Cail and on behalf of Expert Village, I'm here to show you how to make Frankenstein's monster. Frankenstein traditionally has electrodes. These electrodes are on the side of his neck. It's what helps give him life when the electric current went... Read More »
Obtaining a marriage license is an important step in making your marriage legal. Follow these guidelines on how to obtain a marriage license if you plan to wed in Oregon. Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
