Nozzle - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2013, 07:17 AM   #1
nozzle
Can you replace a .85 70A nozzle with a .85 80A?
ThenorNCo is offline   Reply With Quote
Old 10-25-2013, 08:33 AM   #2
An old Tradesmen
Rewards Points: 7,808
Doing so, can cause damage to the combustion chamber.
Old 10-25-2013, 09:18 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 134
No. It is a 10 degree wider angle of spray and will hit the chamber and damage it.
Old 10-25-2013, 10:38 AM   #4
FClef's Avatar
Rewards Points: 160
While everyone says no, I will tell you that it depends on the overall firing rate of the boiler, the recommended nozzle size and the overall size of the combustion chamber. The nozzle could work as long as there is no flame impingement on the chamber, but you need to be able to see that. My suggestion is to change it out with what was in there to begin with.
"Human beings can always be relied upon to assert, with vigor, their God-given right to be stupid"
Dean Koontz - Seize The Night
FClef is offline   Reply With Quote
Old 10-25-2013, 10:42 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 134
actually it may not work as the electrodes would have to re repositioned or it may not fire properly or have delayed ignition.
Old 10-25-2013, 05:04 PM   #6
Rewards Points: 582
thats what scares me ..it could have delayed ignition .. over the yrs it was always best and still is to replace nozzles at the exact size....ben sr
Old 10-25-2013, 06:58 PM   #7
Rewards Points: 242
Why would you want to?
hvac instructor is offline   Reply With Quote
The Following User Says Thank You to hvac instructor For This Useful Post:
ben's plumbing (10-25-2013)
Old 11-11-2013, 08:52 PM   #8
Its a big chamber and i dont think 10 degree wider will hurt.
Old 11-11-2013, 09:30 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 134
use whatever the furnace manufacturer recommends or you may be sorry and damage the chamber and it can void the chamber/heat exchanger warranty. they can tell by color discoloration what was in there. you will have to reset the electrodes to get it to light properly.
Old 11-12-2013, 04:38 PM   #10
Thanks...i am replacing it.
down sizing an oil burner nozzle bernie963 HVAC 11 01-09-2013 05:49 PM
Powerwasher losing water near the nozzle Girly_girl Plumbing 1 09-22-2011 08:37 AM
Duo-Therm 86505 Nozzle Confusion? sjb49938 HVAC 0 10-05-2010 05:06 AM
changing a nozzle on a beckett afg johnnyd60 HVAC 5 09-22-2010 04:41 PM
carbon build up on nozzle zuni97 HVAC 8 01-20-2009 08:02 PM
