Now What Did I Break? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 06:45 PM   #1
Now what did I break?
I have an early 80's model Dou-therm furanace in a mobile home 2 wire hook up, No cooling. I don't thing there is a circut board. Furnace is clean and still in good shape. I got a Lux programable thermostat I just installed. It worked for a day and now the furnace won't fire up. The pilot is lit and I read 24 volts across the stat wires. I jumped the wires and still nothing. I'm getting my tools together. Is there a relay switch I should look for. And be able to possibly jump to test. There is power in and out of the transformer. Thanks for any words of wisdom.
Baloo is offline   Reply With Quote
Old 02-26-2013, 09:09 PM   #2
as seen on tv
Rewards Points: 150
Reading 24v across stat wires indicates an open. Where did you measure at the stat or the furnace
qbert is offline   Reply With Quote
Two quotes - difference of more than double? (pricey one doesn't even break cement) buckybadger Plumbing 2 09-17-2011 10:25 PM
DP Thermostat - thermostatically break BOTH lines docdoor Electrical 4 10-21-2010 03:54 PM
Delay on Break timers rjbaiad HVAC 6 09-24-2008 06:17 AM
Just can't break sink drain free! DIYtestdummy Plumbing 6 03-05-2008 10:56 AM
