Now Outside, Cold Inside - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 01:04 PM   #1
snow outside, cold inside
Hello, I have a Bryant 395cav furnace & being english also no knowledge on this way of heating, just practical experience. However this one does not stay lit when the gas comes on, not often.
Replaced the over heat sensor as this was internally open circuit & also cleaned the flame sensor.
However on looking at internet problems it may be the gas valve or control circuit board, seem to not have voltage to gas valve & believe it should be 24 V ac ? Again unsure, if circuit board faulty, why will it work on self test alright but not in use ?
Any thoughts greatly appreciated.
kirkbarrow.gara is offline   Reply With Quote
Old 12-01-2010, 03:25 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
look through sight glass in blower door and count flashes to get code, chart should be on back of blower door ..... check this when furnace is acting up, also best to have a pro look at the heat exchanger as they are known to crack on that model
hvactech126 is offline   Reply With Quote
Old 12-01-2010, 03:32 PM   #3
Sorry to be so ignorant, but as I said am english.
Have got no idea where blower door or led for error codes are.
I have been trying to work out, but no circuit diagram ,one on door just mouldy and damp/faded and new to these thing's.
Thankyou anyway
Old 12-09-2010, 09:54 PM   #4
LED Error Code
Hello again, found the led for said error code's. It was on the new control board. The old one never had one on it, so suggesting I check a non-existant code led would not help. Anyway, I did solve the problem, no power supplied to the gas valve. Thank's " Mr Professional ", I won't call on your " help " again.
Old 12-10-2010, 04:49 AM   #5
An old Tradesmen
Rewards Points: 7,746
His crystal ball probably isn't working. So he was suppose to know that your board didn't have an LED how?
Old 12-10-2010, 05:55 AM   #6
Rewards Points: 1,216
kirkbarrow, take it easy the guy was only trying to help. Call a HVAC pro if you want it fixed. The people on here do the best they can without seeing the equipment. It's like a Doctor diagnosing you over the phone.
COLDIRON is offline   Reply With Quote
Old 12-10-2010, 09:15 AM   #7
RE:- Fixed
Hello Coldiron, Sorry for appearing sarcastic, and I do not need a " Pro " to fix it. As it said in the post I put up, " The led was on the NEW board !
This means to say it was the OLD board that was not turning the gas valve on, so no gas = no heat.
But thanks for the thought, and crystal ball, thankyou too, but I would imagine a fair number still work really well with the original control board's that still have not got an led too.
Old 12-12-2010, 07:49 AM   #8
An old Tradesmen
And you should then also imagine that we can't know if your unit has the original board in it, if you don't tell us.
And since you failed to post the full model number of your furnace. We also can't tell what revision it is to know which board it came with. Yes, they change the boards used in the model line from time to time.
Old 12-12-2010, 02:21 PM   #9
hey smart guy. your not going to get 24v to your gas valve untill the singal gets sent. so your testing it wrong you need to ohm it out to see if its good. and you most likely have other problems just to let you know, but dont go being mad at people your asking for help from. so good luck on figuring it out. and grab some extra blankets.
hvac kid is offline   Reply With Quote
Old 12-12-2010, 02:31 PM   #10
Smart guy ??????????
Hey " hvac kid " your not reading close enough ! If ??????????
you had read closer ???????
you ! would ?????????
maybe ?????????
of read that my THIRD POST had said the NEW control board had the LED on it, so reading the THIRD POST would let you know the control board WAS the problem and also as it had the LED on it, I had now believe it or not ?????????
got HEAT.
So for all the " PRO'S " out there, being english, knowing nothing, I fixed my own furnace and NEVER PAID FOR ANY OF YOU saving my money,
average $95 call out charge before you do anything.
Old 12-12-2010, 05:08 PM   #11
An old Tradesmen
Originally Posted by kirkbarrow.gara;550036
So for all the " [B
PRO'S[/B] " out there, being english, knowing nothing, I fixed my own furnace and NEVER PAID FOR ANY OF YOU saving my money,
Congratulations.
Just remember. If you keep being too sarcastic. And ever need help to fix your furnace. You may burn the bridge to that "free" help that is provided by "pro" HVAC techs here.
While you may not have received the help you wanted. Thousands of others do and have.
The Following User Says Thank You to beenthere For This Useful Post:
bbo (12-12-2010)
Old 12-12-2010, 08:15 PM   #12
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
what is the english word for dick??????????????? you guys do the best you can with the least amount of info from some posters and then take crap for it, go figure??????????????????
hardwareman is offline   Reply With Quote
Old 12-13-2010, 06:24 AM   #13
You're lucky for a guy who didn't even know where the blower door was.
You sure it was a heater????????????????????????
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 12:21 PM
Need advice on cold air return mrlouie HVAC 4 10-09-2010 04:33 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 12:43 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 10:50 PM
