Is NOW A Good Time To Replace My 1986 AC? - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 07-24-2013, 05:41 PM   #46
Hvac Pro
yuri's Avatar
Rewards Points: 384
Originally Posted by FixitDragon View Post
1dB is the smallest incriment, or change in sound, most people can decern
3dB incriment is double the sound energy, but NOT what we perceive as double the volume. (This is where some confusion comes from) In audio terms, it takes twice the power to increase the sound by 3dB, but we do not perceive 3dB to be twice as loud, only somwhat louder
10dB incriment is an order of magnitude more sound energy (10x), and what we perceive as "twice as loud" In audio, it takes 10x the power to make something twice as loud.
In terms of ACs, you will notice some difference between 74,70, and 66, the 74 will seem about 75% louder than the 66. Don't pay a bundle to gain 3dB for something that sits outside, air handler is a much larger factor for the noise in the living spaces.
(yea, I am an engineer )
I disagree somewhat. If it sits on his patio then sound is an issue and worth spending $$ on and if it is outside a bedroom window and can be heard then it is worth spending $$ on a quieter unit IF the customer wants that or cares at all. My neighbor could sleep on his deck with train tracks not far away with no problems. Need to drop a bomb beside him to wake him up. Myself I worked shift work and like to use ear plugs or had to. Depends on the individual and how lightly they sleep.
Old 07-24-2013, 10:24 PM   #47
Experienced HVAC Tech
HVAC1000's Avatar
Originally Posted by raylo32
Why is that, Yuri? Bigger coils? My GF has a Trane 16 SEER heat pump and it is enormous.
More coils= more surface area to transfer heat
HVAC1000 is offline   Reply With Quote
Old 07-24-2013, 10:55 PM   #48
Can certainly see your point. I am a pretty light sleeper (you never sleep heavy with kids in the house!) but with my AC I tend to notice the air handler more (high rpm direct drive) even with the condenser on the other side of the wall from our bedroom.
FixitDragon is offline   Reply With Quote
Old 07-24-2013, 11:37 PM   #49
DIYer
Rewards Points: 262
Just downloaded the free app and ran some tests uncalibrated...
When I sit in my family room with the HVAC off I hear crickets and the fridge in the kitchen (about 15 ft away)...32 db. My windows are old.
With the AC on, I initially hear the outside unit as it fires up but once the air is moving inside that is louder than the outside unit. I am surprised. 42 db.
The outdoor unit is about 10 feet from my ears. The furnace is downstairs in the basement. I cannot hear it run unless I go downstairs. I can hear the WHOOSH of air when the furnace is on.
I walked over to the air return in the foyer and I got 54 db.
I went outside...crickets are 61 db. If a car drives by, it goes to 64 db (I'm on the back side of the house 150 ft from the road).
AC unit running and me 2 ft away is 77 db. It is old school single speed and always makes the same noise.
I walked to 20 ft away where I'd be sitting on my patio and got 67 db.
mystic_cobra is offline   Reply With Quote
Old 07-25-2013, 05:17 AM   #50
raylo32's Avatar
Rewards Points: 1,294
I think quieter is almost always better. My unit is like the OP's... single speed, old. It's about 77 dB a couple feet away. But it is 2 floors below my bedroom and sits below a deck so really isn't an issue for sleeping. I will still go for a quieter one for replacement.
Then there is a situation like at my GF's condo. All the condensers are lined up on one outside wall. So even though she replaced hers with a nice quiet unit there are still a couple of the original rattle traps out there that are loud, especially in heat mode. If you want to sleep there you just have to get used to it.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 07-25-2013, 07:59 AM   #51
Hvac Pro
yuri's Avatar
Rewards Points: 384
sounds like (no pun) your test is accurate. some of the entry level new units are 76 db and some of the older units of your era were heavy built so it is not so bad in comparison. all I can say is that I can stand beside a 70 db unit and talk to someone w/o raising my voice. not so with a 76 db unit, have to talk fairly loud. now you have 2 reference points to use 77 and 70 to see if spending extra $$ is worthwhile.
although in your first post you said it bothered you inside the house while watching tv and while having guests on the patio, there are quieter than 70 db units, just depends how much you are willing to pay for that lack of sound.
your choice of course, at least you have some science to work with now or the app is not very accurate.
Old 07-25-2013, 09:15 AM   #52
Hvac Pro
yuri's Avatar
Rewards Points: 384
louder in Winter why??
because air is denser when it is colder out and sound travels further.
especially in the Great White North. I can hear your dog barking in mid December
Old 07-25-2013, 09:52 AM   #53
raylo32's Avatar
I don't know why... maybe the reversing valves? Or maybe the cold affects the case and access panel clearances enough to induce rattles? I dunno but a couple of these really make a racket. Maybe the cold air/sound transfer, too, although in this case we are talking just 10-30 feet away.
Old 07-25-2013, 11:16 AM   #54
HVAC1000's Avatar
We don't have many heat pumps here so someone tell me if I am wrong, but what I learned in school is that they are much louder when they go into defrost mode. I'm not really sure though so ya.
Old 07-27-2013, 11:29 PM   #55
DIYer
Rewards Points: 262
Had another guy come out today and survey to give me a quote. We discussed the differences between the 80% furnace and the newer condensing furnaces. He was nice enough to explain the details so I understood and what would have to be done to upgrade. I also read a bunch online about the differences. I was a little worried about using PVC for a furnace exhaust initially but after reading the details it makes much more sense. I had no idea the exhaust was so cool.
The location of the vent is now a major consideration regarding the distance to the windows, soffits, etc. So much to consider...
Old 10-02-2013, 10:23 AM   #56
DIYer
Rewards Points: 262
I am back at this now that fall is here. I'm evaluating my options and I am looking for some clarification...
My current system uses 3" round metal pipe from the furnace and the HWH and they merge at a Y and then go through the wall into the chimney. I'm assuming that the metal pipes don't go all the way up. From the top, you can see the two red square "pottery pipes" like this: http://www.bandbrenovationsandchimne...ney%20Caps.jpg
Is it correct that if I go with an 80% furnace I will need a metal chimney liner (or two)?
And that if I go with a 95% furnace, I won't need a liner but will have to run the set of PVC pipes outside? Does the HWH still need a liner if I go with a 95% furnace?
I'm trying to figure out the difference in cost for the ancilliaries associated with each choice.
Old 10-02-2013, 12:40 PM   #57
Hvac Pro
yuri's Avatar
Rewards Points: 384
we call that a clay tile liner. where I am the gas code states that you HAVE to have a liner and you got away with it due to the grandfather/ as is clause. once you update any wiring or gas appliances then you must update to the new code. you will need a liner for the water heater unless your code does not require it. you will need a smaller B vent insulated liner as there is not enough heat coming out of a water heater to warm up the chimney and it could condense and freeze it up. where I am all new homes have a high eff furnace, no chimney and use a elec water heater or thru the wall type. you lose LOTS of air/heat/$$ up chimneys so getting rid of it is a good idea to save NRG/$$.
any reputable contractor should know the gas code and tell U what U need.
The Following User Says Thank You to yuri For This Useful Post:
Mikhail (11-06-2013)
toilet backing up, random bubbling in sink. this can't be good. wkd Plumbing 2 05-17-2013 10:25 PM
re: replace asphalt driveway. best method?? gramps416 Building & Construction 12 05-24-2011 11:50 AM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Time to replace roof? ken123 Roofing/Siding 6 03-25-2010 12:33 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 08:39 AM
