Not Enough Wires? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 08:20 PM   #16
What are you going to do with this data?
Master of Cold is offline   Reply With Quote
Old 08-22-2011, 08:32 PM   #17
Rewards Points: 6,652
I am using it to compare to my billing from our utility company, and also it is used as a resource for others to compare to others through the website that gathers all of this. I also used it to help tweak the swing & differential on the thermostat, so I am able to be more proactive in heating and cooling the house. Since our utility for gas & the city owned utility for electricity/water/sewage does not use any device to allow you to monitor your daily KWh, and no, I am not going to go out there to read the meter everyday, which would not be an accurate way of reading, due to that would include the whole house. it makes it easier to use to compare billings from one year to the next.
Old 08-22-2011, 09:15 PM   #18
raylo32's Avatar
Rewards Points: 1,286
Thanks Greg, I'll check that out. I have a computer running 24/7 that would be ideal for this.
[quote=gregzoll;713156]raylo32, grab thermostat monitor at thermostatmonitor.com, and thermostat for windows at setyourthermostat.com. If you want to just pull up, you can pull the stats by IP/tstat/datalog through JSON. I used the Firefox addon to pull this:
raylo32 is online now   Reply With Quote
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 08:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
