Not Cooling Evenly - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 09:49 AM   #1
Not cooling evenly
Just a quick question (I'm new here )
I recently took down the vents in our home for replacement, and have yet to put the new ones in place (I'd like to get the walls painted before I do it) but I've noticed that my home is cooling very unevenly. Our bedrooms, office and bathroom are cool, but our kitchen and living room seem to be roasting.
Can the vents on an forced air system cause this much havoc with the air flow?
Any help I can get would be greatly appreciated.
Thanks!
jasonaroth is offline   Reply With Quote
Old 06-01-2011, 11:38 AM   #2
Rewards Points: 150
From what you said it sounds like your ducting is in the attic, you might check to make sure it is all connected sometimes over the years joints fail. You can close the vents in the colder rooms to help in the warmer rooms.
josall is offline   Reply With Quote
Old 06-01-2011, 12:00 PM   #3
Actually, no, our ducting is in the walls. We live in a condo on the third floor of a building.
And as I said, all the vents are currently off the walls because of remodeling going on.
I guess I should ask this better- Will not having vents on my ducts effect the cooling distribution through the house?
Old 06-01-2011, 12:24 PM   #4
30 year tech
hvac122's Avatar
Yes it could.
hvac122 is offline   Reply With Quote
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 03:21 AM
lennox g20 whisper heat cooling mood cargom HVAC 0 09-25-2010 09:41 PM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 03:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 09:56 AM
kenmore 596.58695890 cooling issues mindraven Appliances 7 08-22-2009 08:00 AM
