Not All Baseboards Working - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 05:09 PM   #1
Not all baseboards working
My basement baseboard does not produce any heat. Its one unit with lines coming down from each end. One is hot one just luke warm. No bleeder valves. This is a hot water boiler.
johncheri is offline   Reply With Quote
Old 01-15-2012, 05:20 PM   #2
HVAC Tech/ Browns Fan
Follow lines to warmest area ( other rooms) Then bleed from there. But if you don't know what u are doing don't fix it. You can cause more headache then what you have right now
Tator1076 is offline   Reply With Quote
Old 01-15-2012, 05:30 PM   #3
thanks
That was my original thoughts, I dont want to create more work.
Old 01-15-2012, 07:14 PM   #4
biggles's Avatar
so it come out of the boiler loops the house and back to the boiler what is the temperature setting within the boiler or on the aquastat. was it working and crapped all of a sudden.the hot pipe you sholdn't be able to grab the return you should...that temperature difference is what is in the rooms.note back here the boiler cycles off at what temp and what pressure both read at the boiler forget the stat...need to know yourr water heating setpoint
Old 01-15-2012, 11:55 PM   #5
how
Rewards Points: 1,104
A picture of your boiler system might help.
Do any of your baseboards in the house have bleed valves? Do you have more than one thermostat ? Do you have auto bleed valves at the boiler? What does the tridicator guage on the boiler show when its running in PSI and temp. Do you hear water running through the baseboards or heating lines?
The answers to these questions can help point out why you would have an apparent air lock in the most unlikely location on your boiler system and perhaps the way to deal with it.
how is offline   Reply With Quote
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 10:05 AM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 06:23 AM
Upstairs baseboards not getting hot secutanudu HVAC 20 11-06-2010 10:30 AM
Baseboards before or after skimcoat? BagOfMostlyWate Drywall & Plaster 5 10-23-2010 08:43 AM
Should new baseboards go on top of carpet? hawks81 Flooring 4 08-23-2010 11:25 AM
