Not Able To Adjust Pilot - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 09:25 PM   #1
not able to adjust pilot
I have replaced a honeyweel standing pilot gas valve in a modine unit heater. The pilot remains about 10 inches after I have turned the pilot adjusting screw. Anyone with any thoughts?
andrew1 is offline   Reply With Quote
Old 10-22-2012, 09:53 PM   #2
Sounds like you lost the pilot orifice.
The Following User Says Thank You to Marty S. For This Useful Post:
andrew1 (10-26-2012)
Old 10-22-2012, 10:43 PM   #3
Rewards Points: 610
I was thinking the same as Marty even before I read his comment.
Check the end of the pilot assembly. Should have brass fitting ..like small bolt head with an orifice hole in the center. If just hollow end with threads then orifice fitting is missing. Look in bottom of unit?
techpappy is offline   Reply With Quote
Old 10-22-2012, 10:52 PM   #4
Missouri Bound's Avatar
Any chance you have a NG valve on a LP line? (But I'm going with the orfice answer).
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
plummen (10-22-2012)
Old 10-22-2012, 11:07 PM   #5
how
Rewards Points: 1,104
Did you disassemble the pilot assembly from the pilot tube in addition to replacing the gas valve? A little history would help!
Even without a pilot orifice, I don't see why you couldn't adjust the pilot flame down to nothing especially with a new valve, even though it would be a pretty soft flame.
Something sounds off here.
how is offline   Reply With Quote
The Following 2 Users Say Thank You to how For This Useful Post:
ben's plumbing (10-23-2012), plummen (10-22-2012)
Old 10-22-2012, 11:41 PM   #6
I did change the pilot assembly. Didn't notice any piece coming off though I may have missed it. I tried 2 different new valves and the are both doing the same thing. 10 inch yellow flame. After trying 2 valves with the same result I began to wonder if the pilot assembly is the problem but I thought the pilot would still at least increase or decrease . Thank you for pointing me in the right direction. I will check it tomorow morning.
Old 10-23-2012, 06:06 PM   #7
Rewards Points: 196
orfice fall out, or someone tried cleaning with a 6 penny nail
HVACTECH96 is offline   Reply With Quote
The Following User Says Thank You to HVACTECH96 For This Useful Post:
Old 10-26-2012, 10:19 PM   #8
Thank you all... Orifice fell out just as you said... Problem solved
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Gas Water Heater w/ Electric ignition - no pilot Sparkus Plumbing 0 12-24-2011 05:10 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
How do I adjust the gas flow to the pilot light on my furnace? 4nxchg General DIY Discussions 2 10-20-2009 12:58 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 09:37 AM
