Old 11-12-2007, 10:58 AM   #1
Is it normal for a Heat Boiler shuts off and on?
Is it normal for a Heat Boiler to shuts off and then back on before reaching the set temperature on the thermostat?
I have a heat boiler which i notice that it shuts off itself and then turn itself back on (for a couple of times) before reaching the set temperature on my thermostat.
-Thanks
gforce is offline   Reply With Quote
Old 11-12-2007, 11:36 AM   #2
I have gas!
Clutchcargo's Avatar
Yes, the boiler will fire until it hits 180°F (might be different, depends on what the boiler is set at). The water continues to circulate through the radiators. When the water cools down to around 150-160°, it will fire up again.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
