-   -   Is it normal for a Heat Boiler shuts off and on? (http://www.diychatroom.com/f17/normal-heat-boiler-shuts-off-13320/)
gforce 11-12-2007 10:58 AM
Is it normal for a Heat Boiler to shuts off and then back on before reaching the set temperature on the thermostat?
I have a heat boiler which i notice that it shuts off itself and then turn itself back on (for a couple of times) before reaching the set temperature on my thermostat.
-Thanks
Clutchcargo 11-12-2007 11:36 AM
Yes, the boiler will fire until it hits 180°F (might be different, depends on what the boiler is set at). The water continues to circulate through the radiators. When the water cools down to around 150-160°, it will fire up again.
