Nordyne System - HVAC - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 11:39 AM   #1
Rewards Points: 180
Nordyne system
How do i find the year of the nordyne heat pump system if i only have model #-GQ3RC-036k?
Also what are some issues these have been known to have?
Any info is appreciated.
hidden 1 is offline   Reply With Quote
Old 03-21-2013, 12:46 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 174
you need the serial #. or if you open the electrical box cover inside the unit with the power off and look at some of the parts most of them will have a 4 digit date code or sticker. may need a manifying glass. ie 0690 = 6 month of 1990 or 1693 = 16th week of 1993. 95% of the time I can find a date code.
get it regularly serviced, freon level checked etc and it is no different than any other brand.
Old 03-21-2013, 03:25 PM   #3
Rewards Points: 180
Thanks for the reply but I am not with the unit and was hoping the model# could link me to when they were made.
Maybe the company could help with year it was made/ and when they quit making that model(GQ3RC) .
Old 03-21-2013, 04:58 PM   #4
An old Tradesmen
Rewards Points: 7,816
Thats a 12 SEER packaged heat pump. Pre 2006, probably pre 2002. Serial number would be needed to know what year for sure.
Old 03-22-2013, 04:04 PM   #5
Rewards Points: 484
Those units are pretty stout. Like yuri says, maintenance, charge checked etc. As long as the unit was installed properly, no reason why it shouldnt give a good 15+ years of service.
sammy37 is offline   Reply With Quote
Old 03-24-2013, 10:39 PM   #6
Rewards Points: 180
I found the serial # ,it is GQB010701838.
Would that make it a 07 or a 01?
Old 03-25-2013, 11:12 AM   #7
Looks like it's an '01 to me
http://www.buildingcenter.org/nordyne
JScotty is offline   Reply With Quote
Old low voltage lighting system - switches stopped working. zepman Electrical 14 02-17-2016 07:18 PM
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 11:56 AM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 07:17 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
