Nordyne Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 08:07 PM   #1
nordyne heater
I have a nordyne model FEH-017HA-04 furnace the fan runs full speed when ac kicks on but runs half speed when heat kicks on help
dowsabel is offline   Reply With Quote
Old 10-23-2013, 08:46 PM   #2
Experienced HVAC Tech
HVAC1000's Avatar
Check the taps on the control board. As long as it isn't overheating. What is your problem with it running slower. The units are factory set to run slower on heating than on cooling less its an ECM
HVAC1000 is offline   Reply With Quote
The Following User Says Thank You to HVAC1000 For This Useful Post:
FClef (10-24-2013)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Heater Height Factor in Install Cost? hefret Plumbing 9 10-10-2013 10:01 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Vacuum breaker with tankless water heater? braman Plumbing 3 04-07-2013 01:40 AM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
