Old 12-24-2011, 12:22 PM   #1
MB1
Nordyne Gas furnace won't stay lit
My furnace runs but does not blow warm air. It tries to ignite for four cycles and then flashes the warning for a weak flame. I thought the issue was the ignitor (which I think includes the Sensor) and replaced the ignitor (carbide, pinky size with white nipple on end, and two wires at the end). I have a nordyne 703911a, almost nine years old. (Oh, I was very careful not to damage the new ignitor)
More details: When I cycle on the heat, first I have as solid red light, then gas valves opens and ignitor gets red hot. Gas lights. I get a steady yellow light indicating flame is sensed, then the flame goes out in around 20 seconds, and I get flashing yellow lights indicating a weak flame. Then four red for the lockout due to failed ignition. This cycles four times. Furnace is 9 years old. Thank youin advanc for any advice to my problem!!!
Thank you,
Marcu
MB1 is offline   Reply With Quote
Old 12-24-2011, 12:43 PM   #2
Thank you,
Marcu
locate and clean the flame sensor
harleyrider is offline   Reply With Quote
Old 12-24-2011, 04:13 PM   #3
yes iagree with harley....however some pictures would help since you said you replaced ignitor that included sensor you think..
Old 12-24-2011, 04:18 PM   #4
After re-reading and thinking this post, I am leaning to a dirty pilot/sensor instead of just the sensor. We must remember that a good ground is crucial as well.
The Following User Says Thank You to harleyrider For This Useful Post:
ben's plumbing (12-24-2011)
Old 01-03-2012, 11:48 PM   #5
MB1
All, thank you for the replies. Now that I am back from the Holidays, I'm still cold in my place! Attached are some photos. I noticed the weak flame gets blown out once the fan kicks on (i.e almost immediately after it ignites). Here are photos. The ignitor is new. Which is the sensor that I would need to clean? Does anything look wrong? Thank you!!!!
Nordyne Gas furnace won't stay lit-2012-01-03-19.48.42.jpg   Nordyne Gas furnace won't stay lit-2012-01-03-19.49.01.jpg   Nordyne Gas furnace won't stay lit-2012-01-03-19.49.43.jpg   Nordyne Gas furnace won't stay lit-2012-01-03-19.50.36.jpg   Nordyne Gas furnace won't stay lit-2012-01-03-19.50.53.jpg
Old 01-03-2012, 11:51 PM   #6
MB1
Here's one more photo...
Lennox Furnace burner won't stay on stevea7777 HVAC 43 01-07-2013 03:17 PM
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 11 12-16-2012 07:18 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace won't stay lit Fleener HVAC 4 04-03-2009 08:39 AM
Gibson furnace won't stay lit Srx70025 HVAC 5 12-19-2008 11:49 PM
