-   -   Nordyne Gas furnace won't stay lit (http://www.diychatroom.com/f17/nordyne-gas-furnace-wont-stay-lit-127567/)
MB1 12-24-2011 11:22 AM
My furnace runs but does not blow warm air. It tries to ignite for four cycles and then flashes the warning for a weak flame. I thought the issue was the ignitor (which I think includes the Sensor) and replaced the ignitor (carbide, pinky size with white nipple on end, and two wires at the end). I have a nordyne 703911a, almost nine years old. (Oh, I was very careful not to damage the new ignitor)
More details: When I cycle on the heat, first I have as solid red light, then gas valves opens and ignitor gets red hot. Gas lights. I get a steady yellow light indicating flame is sensed, then the flame goes out in around 20 seconds, and I get flashing yellow lights indicating a weak flame. Then four red for the lockout due to failed ignition. This cycles four times. Furnace is 9 years old. Thank youin advanc for any advice to my problem!!!
Thank you,
Marcu
harleyrider 12-24-2011 11:43 AM
Thank you,
Marcu
locate and clean the flame sensor
ben's plumbing 12-24-2011 03:13 PM
yes iagree with harley....however some pictures would help since you said you replaced ignitor that included sensor you think..
harleyrider 12-24-2011 03:18 PM
After re-reading and thinking this post, I am leaning to a dirty pilot/sensor instead of just the sensor. We must remember that a good ground is crucial as well.
MB1 01-03-2012 10:48 PM
Pictures of Nordyne Furnace - Sensor Location?
6 Attachment(s)
All, thank you for the replies. Now that I am back from the Holidays, I'm still cold in my place! Attached are some photos. I noticed the weak flame gets blown out once the fan kicks on (i.e almost immediately after it ignites). Here are photos. The ignitor is new. Which is the sensor that I would need to clean? Does anything look wrong? Thank you!!!!
MB1 01-03-2012 10:51 PM
One more photo
1 Attachment(s)
Here's one more photo...
jakerjenkins 11-20-2013 12:52 AM
did you find out what was wrong with your furnace as i have the same problem with mine
beenthere 11-20-2013 04:45 AM
If the flame goes out as soon as the furnace blower comes on. It generally means the heat exchanger has a crack or a hole in it. And needs replaced. Often better to replace the entire furnace.
