-   -   Nordyne G6TL Furnace Question (http://www.diychatroom.com/f17/nordyne-g6tl-furnace-question-37075/)
kentcasey 01-28-2009 06:34 PM
Hello,
I recently replaced the inducer blower assembly in a Nordyne G6TL 90+ variable speed furnace.
The new assembly has a condensate drain where the original had none. It appears that a small amount of condensate can end up in the blower housing and they decided it needs somewhere to go.
Can I tap this into my existing condensate drain using the same clear vinyl hose and a tee or does it require something more complicated?
Any thoughts would be appreciated.
Thanks!
yuri 01-28-2009 07:43 PM
Make a circular 360 degree trap loop out of small vinyl hose and then tee it into the main drain line. Needs a trap to keep fumes from escaping and to maintain draft thru the ventor.
JohnH1 01-28-2009 08:05 PM
Be sure the highest part of the loop is lower than the induser drain port.
kentcasey 01-28-2009 09:03 PM
Nordyne G6TL Question
Hello,
Thanks![/quote]
hvaclover 01-28-2009 10:14 PM
You got the wrong inducer for your G6. The one you have is for the new G7 models.
