Nordyne Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 10:55 AM   #1
nordyne furnace
nordyne furnace dos not blow hot air and runs every two minutes. has been cleaned and ducts insulated. It is in a trailer house. plastic windows temp is 59 degrees outside thermostate is set at 69 and it runs every two minutes to stay that temp. doesnt seem like air is very warm out of registers.
chargingeagle is offline   Reply With Quote
Old 10-06-2012, 11:34 AM   #2
An old Tradesmen
Rewards Points: 7,278
Check your thermostat for loose connections.
or try turning the thermostat up 10 degrees, and see if it runs longer.
Old 10-06-2012, 06:58 PM   #3
Rewards Points: 610
if old thermostat.... might have a burnt heat anticipater.. Take cover off TT ..find small dial indicator with tiny adjustment arm..look for burn spots,,if not burnt, check adjustment of same..should be set for fuel valve amperage e.g., 0.4 etc.
If not TT then could short cycle due to restricted air flow e.g., dirty filter, A Coil, broken belt on blower, dirty blower ..inspect and clean as necessary
let us know of progress
techpappy is offline   Reply With Quote
Old 10-07-2012, 05:43 PM   #4
nordyne furnace
its a new thermostate and filters. tri cap came in and cleaned furnace, new thermostat, insulated ducts and i replaced thermocoupler, pig tail looking thing for the pilot light. Now it seems to run fine but the air isnt as hot as it use to be and runs every two minutes.
Old 10-07-2012, 05:50 PM   #5
An old Tradesmen
Brand and model number of thermostat. It may have its CPH set too high.
Nordyne Gas furnace won't stay lit MB1 HVAC 7 11-20-2013 04:45 AM
Propane Furnace - Diminishing Gas Supply After Ignition edro HVAC 9 01-13-2012 04:24 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
