-   -   Nordyne condenser goodman A-coil (http://www.diychatroom.com/f17/nordyne-condenser-goodman-coil-53013/)
wtroger 09-14-2009 10:01 PM
I have a Nordyne ds3ba-048ka outdoor unit I purchased three years ago I installed it on an existing older Heil 4 ton a-coil emergency install in the middle of july 100 + degree weather. It works great. I am now going to replace at least the furnace It is a goodman rated to handle up to a 4.5 ton a coil. I have a 4 ton Goodman A coil it uses something called a flowrater that is used by changing sizes if you are mismatching out door units to acoil They also talk about compressor piston size. I need to know if i can put the Goodman a-coil on the Nordyne outdoor unit. They are both 4 ton units I don't know if there is a piston size on the Nordyne. The Nordyne is a R-22 system. the Goodman a-coil will work with r-22 or r-410.
sdsheatcool 09-15-2009 06:11 AM
What I would reccommend is that you get the appropriate TXV ( Thermal Expansion Valve) from Goodman to install onto the new A-coil. This valve meters on temp. and oporating conditions and would solve the problem of unmatched equipment. If you install it as is, it WILL oporate. However you may get a decreased efficiency and may not get the full 48,000 BTU from the outdoor. The TXV is easy to install, it just attaches to the A-coil threaded end. (DO NOT FORGET TO REMOVE THE PISTON FROM THE A-COIL BEFORE YOU PUT ON THE TXV)
hvaclover 09-15-2009 08:15 AM
I am a Nordyne dealer. Thatis a ten SEER unit. It You have the Flow ratot-Piston size are the same names for the device that regulates refrigeratnt flow.
If you are going to use the Goodman coil check the coil label. it may be matched to you out side unit.
This is, assuming, you still have the flow rator/piston from the Nordyne unit. It would have been in a plastic bag with your paperwork or in the control section of the unit.
I would not go with a TXV as they are expensive and are not for giving if mis installed.
TXV valves are good when trying to apply a ten SEER coil to thirteen SEER condenser. They wont correct a mismatch but just makes the unit work as best it can and the circumstances. You get the most SEER the coil can put out and protect the comp from damage.
You don't have a mismatch, just a piston to change.
I have looked up the size and you need a number 80 size piston /Flowrator to the new 4ton coil to the out side unit.
The size is an 80.
Hope this helps
wtroger 09-15-2009 11:10 AM
Thanks for the Info I aasume then all I need to do is insure that I have an 80 flowrater in the goodman A-coil. The coil number is capf4860c6 which is a 4 ton coil. I have not opened up the fitting to see what size flowrator was sent with it. I was hoping since both condenser and coil are 48,000 btu then it would be a match
beenthere 09-15-2009 05:50 PM
Thats not a 48,000BTU coil.
Its a 4 to 5 ton coil. And you may not like how it works with that condenser.
sdsheatcool 09-15-2009 06:34 PM
The TXV from Goodman is under $100 and is almost impossible to install wrong. ( just follow the directions in the box). This will be your best bet for good oporation of the outdoor unit. Make sure it is a 4 ton TXV.
I will add some info in case you do not know. If you install this new coil on the R-22 outdoor unit. When it comes time to change the outdoor unit you will also have to replace the indoor coil again. REASON: As of Jan.,1 2010 there will be no more R-22 refrigarant equipment manufactured. The new refrigerant R410A is NOT compatible with the R-22 and any oil left from the R-22 will contaminate the 410A and damage the compressor. At this time the U.S.Gov. has a federal tax credit of up to 30%(max. $1500) for a system upgrade. Which may make this a perfect time put in a 410A sytem and recover some of the cost. More details available at energystar.gov
hvaclover 09-15-2009 07:32 PM
I disagree with you there.
beenthere 09-15-2009 07:40 PM
Disagree all you want.
But till you give reasons. Your arguing with yourself.
hvaclover 09-15-2009 09:18 PM
HHHmmmmmm Don't know what the reason for that jab was but I it wasn't necessary.
You would normally come back with the reasons to back your reasoning not a sarcastic shot..
Do we have a problem I don't know about?
Termite 09-15-2009 10:39 PM
Again? Really?
beenthere 09-16-2009 04:52 AM
Not that I know of.
I don't know if you disagree with that not being a 48,000 BTU coil.
Or that he may not like the way the Nordyne and Goodman coil perform together.
Until you say which one of those statements, or, now that I think about it, if its both statements that you don't agree with.
I Don't know which statement to give the reasoning on.
