Noobish Duct Connection Question - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 09:24 PM   #1
Ok, I'm embarrassed to even ask this but I've done some duct work and it always kills me on how to connect the pieces together. For example, I just bought some duct work to connect the hot water heater pipe to the chimney. I needed to convert the 3" pipe from the water heater outlet to the 6" chimney hole. So obviously I need a reducer so the best match I could find was a 6x4 and a 4x3 reducer.
The part that always kills me though is how to connect the pipes together? The 4" part of the 6x4 is exactly the same size as the 4" end of the 4x3. So I've been using tin snips to notch out pieces from one end and squeeze it in the other end. Definitely not easy. Am I missing something or are these connections always this difficult?
jonathan03 is offline   Reply With Quote
Old 12-29-2008, 10:52 PM   #2
you need a tool called a crimper or you can try using needle longnose plyers put it on the pipe and twist about 45 degrees keep moving it till youve gone all the way round but the pipe should come with one end crimped already ok sorry just reread your post , yea the fittings arent factory crimped
kennzz05 is offline   Reply With Quote
Old 12-30-2008, 06:25 AM   #3
An old Tradesmen
Rewards Points: 7,304
A crimper makes it an easy task.
Old 12-30-2008, 07:28 AM   #4
Will a crimper ruffle the edges or cut out metal tabs? I have seen either style in the store. And is there another name for it than crimper? A search at Home Depot yielded all kinds of electrical crimpers to strip off insulation from a wire. I don't think this is the same is it?
Thanks.
Old 12-30-2008, 07:52 AM   #5
An old Tradesmen
It Crimps.
http://www.drillspot.com/products/66..._Metal_Crimper
Duct question kc5oh HVAC 2 08-26-2008 08:03 AM
Question Re: New Furnace and Duct Sizing DSimo HVAC 3 06-17-2008 07:24 AM
Deck Ledger Connection Question frederic.katz Building & Construction 2 05-08-2008 01:13 PM
Duct Work Question xlr8tn HVAC 1 01-19-2008 09:02 AM
Duct sizing question Rob HVAC 1 06-04-2005 12:42 PM
