Noob Design Question - HVAC - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 12:57 PM   #1
Noob design question
I have a new house in NC. I took one upstairs bedroom and made it into a computer room (his & hers). Because of all of the equipment, that room is always hot. I put reflective window coatings on, but that is not enough. I need to add an A/C duct for the summer and be able to turn both off for the winter. If I manually close the vent, it whistles. Do I just add another duct and vent and put (2) dampers in the attic? Will this stop the whistling? Is there a better way to solve the problem.
GaryK is offline   Reply With Quote
Old 03-14-2010, 01:12 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,266
MOST of the time (95%) your house A/C will not have enough extra capacity to handle the additional heat load. More ducts won't help. You need a window shaker or a minisplit:Fujitsu Ductless Mini-Splits: Wall Mounted Systems
We get your scenario dozens of times a summer. Along with excess heat from home entertainment rooms.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Pergola over Deck Question figgyb44 Building & Construction 2 06-10-2008 07:50 PM
noob wireing question shame302 Electrical 6 05-16-2008 08:33 PM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 05:48 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
