Non Standard Ductwork Sizes - HVAC - DIY Chatroom Home Improvement Forum
Old 07-10-2008, 03:05 PM   #1
The Big Builder
Hello all,
I am in the the process of refinishing my basement and the duct work is hanging a little too low. It is 8 x 10 and hangs down about 2 inches from the floor joists. Since I am seven feet tall and need all the headroom I can get, I would like to change the dimentions of the ducts. I know that 8' is the standard btu I was wondering if some company makes some stock sizes that are 6 x 14 or similar.
If I can find these and hang them closer to the joists I will gain about 4 inches room.
Any leads or tips would be great.
Thanks,
Stephen
bigbavarian is offline   Reply With Quote
Old 07-10-2008, 03:26 PM   #2
Rewards Points: 150
custom
call up you local hvac company and ask them if they have a plasma cutter (they can make it allot cheaper then ones that dont) Im sure that they will sell it to you, you will also need slip and drive because they usualy get damaged when you tear out .Good luck
geo fan is offline   Reply With Quote
framing around ductwork jcrampton Remodeling 12 08-01-2011 02:31 AM
Are kitchen cabinets standard sizes? Yeti Remodeling 8 01-30-2009 02:20 AM
replace AC ductwork myself funnyfarm HVAC 3 10-03-2006 08:25 PM
Removing ductwork in soffit... inovermyhead HVAC 2 04-02-2006 10:56 PM
