noma electronic thermostat model thm303m
I have two new a/c units and furnace by Trane, the problem I have is that my new noma thermosat wont turn on the a/c unit. I have only two wires to thermostat from furnace, but one has a pigtail and I am guessing there is a resistor in the pigtail for the a/c unit. Is it possible to connect to my electronic thermostat keeping this two wire with pigtail set up? things ive tried:: switching from gas to electric on
thermostat removeing jumper from rc and rh |
Sounds like you had one of the new digital communicating control systems before. What was the model of the Trane stat that you removed?
the stat is a common white rodgers type 1e56w-356
There must be something special at the other end of that two wire setup. I've never seen such a thing. Normally, you need at least 3 wries for heat and ac. Normally more.
if their is a resistor in the pigtail would it not send lower voltage signaling the a/c unit only to start? thier is something in the furnace end called " ADD A WIRE" by total line.........
Hi rickevin29
I would reccomend goin to the furnace and finding out how it is wired. mdshunk could be right the thing you are calling a thermostat that you removed could be a dc interface. The thing you saw called an add a wire, goes to the g circuit and allows the a/c switch to operate the blower circuit. If you have a 24 volt circuit for your thermostat you will need to leave the rc-rh jumper in. I will give you the termanology so you understand what those letters mean. RC= 24 VOLT HOT, COOLING CIRCUIT RH= 24 VOLT HOT, HEATING CIRCUIT W= 24 VOLT OUTPUT, HEAT Y= 24 VOLT OUTPUT, COOL G= 24 VOLT OUTPUT, BLOWER C= 24 VOLT COMMON OR NEUTRAL, NOT TO BE COFUSED WITH GROUND. Let me know if you need any more help Rusty |
Judging from your posts it sounds as if you know a thing or two about thermostats so I'm hoping you can help me out. I am trying to change my existing thermostat (Weathertron) for our heat pump with a Noma THM303M. The wires that are attached to the existing thermostat are labelled as follows: R, G, Y, X2, B, W, F, O There is a wire running from X2 to W in addition to the wire that is going to X2. This wire does not come from the wall but appears to connect X2 to W (hopefully that makes sense). The connections for the Noma unit are as you have specified them in your 11:40 am post. Any help you can provide would be appreciated! Murray |
hey carrierman, All i did was connect the one pigtail wire to the a/c swith on the thermostat and it worked just fine, the reason it wasnt working before is that there is a 5 minute time delay when switching to a/c to protect the a/c compressor..............thx for all the help guys........:)
| All times are GMT -4. The time now is 06:07 PM. |
