Noisy Trane XE 1000 Outdoor Compressor - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 12:52 PM   #1
Noisy Trane XE 1000 outdoor compressor
Often I'll hear a loud whining coming from my Trane XE1000 compressor outside. Maybe bearing noise?
This is a heater pump with the "auxiliary" stage. Btw, my last electric bill was $350 and I used 1000 killowatts more than I did last year for this month.
Anyways, my limited research shows that replacing the fan compressor in the outdoor unit may resolve the noise problem.
I'm fairly mechanical and love DIY stuff. I just need to know of this will be as simple as shutting off the breaker at the compressor outside and doing a simple swap with the unit that Grainger will sell me?
Or will I have to mess around with refrigerant lines? That would be something I'd prefer to leave to a professional.
Thanks for any suggestions!
Btw, I'd like to also clean the unit while I'm doing this. I'll search the board for info on that.
CZ DIY is offline   Reply With Quote
Old 02-06-2010, 12:56 PM   #2
Here are pics of the unit in case anyone is interested.
First day I moved into the house... yes those lighter fluid bottles below were removed immediately after taking this pic.
Old 02-06-2010, 02:21 PM   #3
An old Tradesmen
Rewards Points: 7,268
Are you sure it isn't your reversing valve making the noise.
Usually if its a fan motor. It will make the noise all the time.
Old 02-06-2010, 03:16 PM   #4
No, I'm not certain. Other than consistency of noise, is there a good troubleshooting method to be certain which is the culprit?
The noise is not constant every moment the fan is on. It comes and goes. I haven't paid attention to exactly when it comes on. But when it is screetching/whining, it usually is like that for several minutes.
Btw I do use the auxiliary heat quite a bit. I hate being cold.
Old 02-06-2010, 03:36 PM   #5
An old Tradesmen
Go outside and see if its in defrost while making the noise. If it is. Then the fan won't be running, and you'll know its not the fan.
Old 02-07-2010, 11:29 AM   #6
Thanks, beenthere. I just noticed the high pitched sound again. So I checked my thermostat and it was in normal operating mode (not aux). I then walked outside and see that the fan is spinning.
I took a short video so folks could hear the noise. Much of what you hear is the normal "rushing" sound of the fan spinning. But you can also hear the high pitched sound that has me concerned.
Here's the video:
Thanks!
Old 02-07-2010, 11:36 AM   #7
An old Tradesmen
Sounds a bit like blow by in the compressor.
is the large line hot while its running.
Old 02-07-2010, 11:47 AM   #8
Right at the moment, aux is on. The whine is gone. And yes, the large line is too hot to touch for more than a few moments.
Old 02-07-2010, 11:49 AM   #9
Whoop, the aux shut off and the whine is back. The top line is still pretty warm.
Old 02-07-2010, 11:57 AM   #10
An old Tradesmen
Check your indoor coil. Could be too dirty.
Old 02-07-2010, 01:22 PM   #11
Thanks again.
To my inexperienced eye, it looks fine. But I don't know what to look for.
Would you recommend a foaming spray-on cleaner or mixed-solution cleaner & brush? I'll ask Home Depot on my way home from work tomorrow. Or is there a preferred solution for sale somewhere on the Internet?
I'll plan to do the indoor & outdoor cleaning next weekend!!
trane electric heater-208 OR
TWE042C140B1
Old 02-07-2010, 01:39 PM   #12
Bottom side of the coil is what you need to look at.
Old 02-07-2010, 02:34 PM   #13
Naaah, still looks clean.
I'm kind of nervous to realize just how bad that looks. The air I breath passes through this!!
I'm going to break out the shop vac right now and brush some of this off. Then I'll do the chemical cleaning next weekend as planned.
Old 02-07-2010, 02:39 PM   #14
I just noticed I have a full thing of CLR (Calcium, Lime & Rust remover). Can I use this to clean the coil with? I just can't go driving to Home Depot right now because I've already started drinking for the superbowl today.
Also have some Jomax.
Old 02-07-2010, 02:48 PM   #15
CLR might eat the aluminum,don't know for sure though. A soft hair brush will get that off.
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 02:32 PM
Need some friendly advice-- Coleman/York v. Trane biggerdaddynj HVAC 3 05-09-2010 10:46 AM
new install of Trane XL15i nind HVAC 32 01-30-2010 12:59 PM
Trane XL 1000 Compressor fan motor wiesph HVAC 5 09-12-2009 04:53 PM
Trane XE 1000 Fan Problem Flathead64 HVAC 15 07-01-2009 09:08 PM
