Noisy Hydronic Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 10:45 AM   #1
Rewards Points: 37
noisy hydronic heat
Hi,
I have hydronic baseboard heaters in a second floor addition. The PEX tubing runs in the floor joist and has been causing a lot of noise. I can hear it on the first floor and the noise is very annoying in the second floor bedrooms. Is there anything I can do short of pulling up the carpet and subfloor to cushion the PEX?
nbmech is offline   Reply With Quote
Old 10-21-2008, 10:52 AM   #2
Has all of the air been bled? Radiant heat is usually quiet unless there is air in the system.
jerryh3 is offline   Reply With Quote
Old 10-21-2008, 10:54 AM   #3
Rewards Points: 37
Yes, i think so. It sounds more like a ticking for a minute or so when the pump starts up.
Old 10-21-2008, 11:41 AM   #4
Make sure that the air is bled out of the system and that you have an air scoop in the system.
If you are absolutely positive that is not the case then you have an expansion/contraction problem and that could be a big issue to fix.
Give me some idea about your hydronic system.
Who put it in? How long ago? Was it put in when the house was built? Is this problem new or has it always been this way? Is it getting worse?
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-21-2008, 11:45 AM   #5
The ticking might be the reflector plates expanding and contracting. There's not much you can do about that now.
Old 10-22-2008, 03:01 PM   #6
Rewards Points: 37
OK thanks
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
bleed a multizone hydronic heat system jsamorug HVAC 5 10-04-2008 08:37 PM
Laminate in Basement over Hydronic Radiant Heat art2670 Flooring 3 10-12-2007 11:17 PM
