Noisy Fan Blower During Start Up - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 02:34 PM   #1
Noisy Fan Blower during start up
I have a 16 year old Trane XE78 furnace with a cage blower which recently started making a noise every time the fan blower start up. it only last for a few seconds and then it runs fine. The noise at time is a bit too loud and at times you cannot hear it. I tried to test the capacitor and after turning the power off I tried to discharge the capacitor, but got no spark at all. I also tested it with an ohmmeter and it show some numbers based on the setting of the meter. Is the capacitor something I can buy at a local Home Depot? I did find one on-line for about $20. I also noticed that the fan blades have some scale accumulation from an old humidifier I used a while ago. Should I start by replacing the capacitor? or should I take out the blower assembly and give it a good cleaning? The motor does sound like a drags for about 2 seconds.
shabtay is offline   Reply With Quote
Old 03-16-2011, 02:44 PM   #2
how
Rewards Points: 1,102
The age, style, brand & model of the furnace would help. Failing capaciter, motor, fan bearings, belt/pulley set up are some possibilities depending on your furnace.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
shabtay (03-16-2011)
Old 03-16-2011, 03:45 PM   #3
Rewards Points: 380
Could just be the dirt in the cups of the fan cage are throwing it out of balance till it gets up to speed (could sound like a ticking noise that speeds up with the fan, or a intermittent scraping sound). Could be the capacitor (generally makes a growling noise on start up). Could be the bearings (generally a dry squealing noise).
Do any of these fit?
Could be the center supports of the cage itself are loose which will make it rattle (but that generally lasts all the time it is turning at higher speeds).
HVACDave is offline   Reply With Quote
Old 03-16-2011, 03:51 PM   #4
Thumbs up
Thanks HVACDave
Hi HVACDave,
Thanks a lot for your response. Yes, I do think it could be the capacitor since it does make a growling noise on start up.
Old 03-17-2011, 01:25 AM   #5
It is very likely a failing cap. Also check the fan/motor mounting bolts and make sure they are sufficiently tight.
On a related note, shorting caps to test them or discharge them is bad for them.
Micah is offline   Reply With Quote
Old 03-17-2011, 09:41 AM   #6
Discharging caps is something you must do before testing. A cap stores energy and if you don't discharge it could hurt you better safe then sorry.
heatycooly is offline   Reply With Quote
Old 03-17-2011, 10:18 AM   #7
Experienced
Jackofall1's Avatar
Sure it might be the capacitor, but the motor is also 17 years I think you said, the noises you are hearing undoubtledly are from the tired bearing of the motor allowing the fan wheel to make contact with the scroll.
While you have everthing apart replace the motor to.
Mark
Old 03-23-2011, 05:36 PM   #8
If the motor is not over amping and starts fine with a new capacitor why would you replace the motor? On a 17 year old system, it isn't worth putting that kind of money into it a capacitor yes a 300 motor no
Old 03-23-2011, 05:53 PM   #9
Experienced
Jackofall1's Avatar
Last time I looked a 3/4 hp motor was $130 maybe you sell them for $300++ but it sounds like this poster is DIY'n it.
I would replace both while I had it apart.
Mark
Old 03-23-2011, 06:15 PM   #10
Your right that motor is cheaper cash and carry all I am getting at is look at all options I would hate to have someone dump a bunch of money into an aging furnace to have another thing go right after it an old system can nickel and dime you. I would do the quick fix and save for a new furnace
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 05:13 PM
Blower Motor Problem curranelectric HVAC 5 08-06-2009 07:04 PM
RPJ2 Blower fan will not stop running number22 HVAC 8 07-19-2009 06:27 PM
Blower keeps cycling on and off simonb HVAC 1 01-17-2009 11:56 AM
