Noisy Ducts - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 11:23 PM   #1
Noisy Ducts
Hi guys. I hope this isn't an often-asked question. I browsed through the first 5 pages of the HVAC forum and didn't see it.
We purchased a home last spring (built in 97), and it has furnace/forced air ducts. The ducts in question are in the unfinished basement, mostly on one side of the house (furthest from the furnace). Whenever the furnace is on, the ducts make noises (pinging, clanging, sometimes quiet, sometimes pretty loud).
So the first question is, what is causing this? Is it simply metal expansion from the heat?
Second, is there a way to quiet this down? The ducts that are making most of the noise are directly under the master bedroom, of course.
TIA for any input.
Jason
jasoncw is offline   Reply With Quote
Old 10-28-2008, 11:51 PM   #2
Probably expansion of the metal as you say.
If they are not screwed together at the joint that could be one way to fix it.
Another might me to use some mastic tape at the joints.
Maybe moving them a little by pushing on them here and there to reduce some stress in the connections.
Just some things to try.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
hard metal vs. flexible ducts katea HVAC 4 05-18-2008 08:23 AM
How far should insulation be from heating ducts... AllGoNoShow Remodeling 4 11-09-2006 05:47 PM
Using PVC ducts instead of standard ducts robertmazzo HVAC 3 10-05-2006 04:26 PM
noisy tap (really noisy!!) - help please Nikki Plumbing 2 04-23-2006 08:56 AM
