A Noisy Damper? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 06:11 PM   #1
Rewards Points: 948
A noisy damper?
One of the two ducts to my bedroom was making a repetitive banging noise whenever the heat came on.
A plumber at my house for another reason looked at it and found a loose seam on a trunk that fed the noisy duct but not the quiet one. He banged on it with a hammer and it got much quieter for a day but then got noisy again.
I called the duct manufacturer and they said to put some screws into the seam to stop it from moving. I did, and 90% of the banging went away.
But an occasional bang, rather like hitting the duct with a small tool, remains.
Over the last week I have been tracking down more loose seams and screwing them, but it doesn't help at all.
There was one part on the duct that connected to the floor that oil canned easily, so I put a bunch of duct tape on both sides, but it still banged.
All I can figure now is that it is the damper. I have it tightened as much as it will go, but it still bangs if you tap on the duct; so I figure it is still free to bang when the heat is on.
There is no obvious way to get at the damper without pulling down the whole duct line, about 15'; and I really don't want to do that.
Any suggestions for:
1) getting at the damper without pulling down the whole duct line
2) what else could be banging.
Thanks much.
Toller is offline   Reply With Quote
Old 03-26-2013, 07:19 PM   #2
how
Rewards Points: 1,070
post photos.
how is offline   Reply With Quote
Old 03-26-2013, 10:19 PM   #3
Rewards Points: 142
Did u check on top of ductwork for tools, etc. that could be making noise? Found a couple links that may or may not help u.
link here 1
link here 2
jmon is offline   Reply With Quote
Old 03-27-2013, 08:42 PM   #4
Rewards Points: 582
did you check to see if the air movement inside furnace is sucking the ductwork in and letting it go when it stops. expansion and contraction...bang...ben sr
Old 03-27-2013, 09:21 PM   #5
Rewards Points: 948
No. Running the blower alone does nothing.
The banging is every few minutes while the heat is on.
I did find a section of the trunk about 20' from the vent that could be oil canning. Is it reasonable to screw something to that to keep it from moving? I don't know if it is actually doing anything, just that it could be moving; only way to rule it out is to "fix" it. Or so it seems to me.
I will take some pictures tomorrow.
Old 03-30-2013, 08:31 AM   #6
Rewards Points: 948
The banging is gone!
I put a hose clamp right after the damper and it reduced the loudness of the banging. I put another right before the damper and it eliminated the banging. So I am all set.
The Following User Says Thank You to Toller For This Useful Post:
ben's plumbing (03-30-2013)
Utica boiler won't ignite / damper culprit? jkr77 HVAC 9 01-10-2013 09:48 AM
basic damper question NZ70UHYp HVAC 1 06-07-2012 08:08 AM
Bathroom fan damper missing is roof vent damper enough?? wantboost HVAC 5 11-10-2011 05:29 PM
Advice needed for zone damper repair... texanfan HVAC 4 07-16-2011 09:22 PM
Installing Flue Liner thru Damper MikeinBurien Building & Construction 0 10-17-2009 12:39 AM
