Noisy From Cold Air Return - HVAC - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 05:02 PM   #1
Noisy from cold air return
A few months ago a contractor was leveling some floor joists to prep for Hardwood installation. Ever since, when the furnace is running, there has been a hum coming from the cold air return closest to where the work was done. The furnace maintenance guy said it was not the fan motor. Any ideas anyone?
okeefferp is offline   Reply With Quote
Old 03-21-2013, 06:03 PM   #2
Bill Kearney
Rewards Points: 1,174
Something left on top of a duct? Like tools or construction debris?
Is it a machine-like hum or a buzz like from electricity? If it's a machine hum then I'd bet on there being crap on the duct. But if it's a buzzing noise then you'd better break out your voltmeter and make sure the ductwork hasn't been energized with live electricity.
wkearney99 is offline   Reply With Quote
Old 03-21-2013, 06:57 PM   #3
It's a hum. I was also thinking that something was left on top of the duct. Guess I'll have to break out the flashlight!
Old 03-21-2013, 09:10 PM   #4
how
Rewards Points: 1,104
If the hum goes away when you place both hands flat against the return air grill, you have a harmonic vibration.
Let us know.
how is offline   Reply With Quote
Old 03-23-2013, 06:40 AM   #5
Noise went away when I placed both hands over the return grill. So how do I fix it? Thanks
Old 03-23-2013, 06:44 AM   #6
Bill Kearney
Over, as in completely blocking the air flow? Or, as in pressing against the frame of the register to help prevent vibration? If it's the latter then it could be as simple as improving how the register is mounted to the duct. If that's the source of the noise. Try removing the register cover (the grille) and see if the noise goes away. If the noise goes away then find a way to better secure the grille so it doesn't rattle.
But if the noise continues after the grille is removed then it's the how the duct is secured inside the wall.
Old 03-23-2013, 03:58 PM   #7
how
If you have a metal return air grill you can
bend every second slat 20 degrees from where they now are with needle nose pliers.
or replace the metal grill with a wooden grill.
Forced Hot Air Heat - No Cold Air Return DIY12 HVAC 27 10-22-2012 09:29 AM
Cold Air Return Duct in Garage Ceiling (for bedroom above) jbrocious HVAC 8 10-15-2012 04:52 PM
Cold Air Return next to supply duct thebigbbm HVAC 6 09-21-2010 05:51 PM
Cold air return, or not? toolman0114 HVAC 1 11-18-2009 05:55 AM
Electric wire in cold air return bvbellomo Electrical 8 01-08-2009 06:01 PM
