Noisy Blower On Startup Of NUGJ125DG03 - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 01:10 PM   #1
noisy blower on startup of NUGJ125DG03
This furnace was installed in 1988, well before I purchased the house, and has been very reliable until last week. It has started to make a loud squeaky noise on startup. I removed the covers and found the blower motor. It said it was permanently lubricated. I guess that means I shouldn't try lubing it but can I?
billondrums is offline   Reply With Quote
Old 03-04-2012, 01:37 PM   #2
biggles's Avatar
shut the service toggle on the furnace and free spin the motor squirrel cage in both directions any grinding or quick stop the bearings are dry.....check squirrel rounds for dirt all should be clean......might slide it out to see if you can lub them or for kicks spray some WD40 in witha tube extender and soak both ends f the motor...easy change out .but doa free spin test in place or slid out...
Old 03-04-2012, 03:27 PM   #3
Could be bearings on the motor or the blower wheel starting to come apart. Either way I suggest hiring a tech trained in heat exchanger inspection to check it out before sinking any money into a 24 year old furnace. At that age it should be getting annual inspections before the heat is needed in the fall.
A cracked exchanger shows no symptoms of being bad in operation until those cracks open wide and the furnace belches out fire when the blower comes on. That's why it's important to get it checked every year on older furnaces.
Old 03-04-2012, 05:21 PM   #4
Rewards Points: 582
thats a furnace by inner city products...... I think at 24 yrs old as mentioned have heat exchanger checked before spending money on this unit....sounds like motor going out...
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
noisy blower / filter box redo BlueBSH HVAC 13 07-14-2011 11:15 PM
Carrier Furnace code 33 @ startup blower fan sounds like jet Frank Ottawa HVAC 6 04-19-2011 08:12 AM
Noisy Fan Blower during start up shabtay HVAC 9 03-23-2011 06:15 PM
Forced Air Blower is too noisy, blows too much air too fast hawks81 HVAC 6 07-06-2010 08:09 AM
