Noises (singing And Rumble) At Main Return Grille - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 11:33 PM   #1
Rewards Points: 202
Question
Noises (singing and rumble) at main return grille
Background info:
We recently had a Goodman Rep out to correct some problems we were having with our dual fuel HVAC system. Our system was installed three years ago. We had all new duct work put in back then, together with these Goodman components:
Indoor coil is Model CHPF3642C6CA; serial 0907129414
Furnace is Model GMV950704CXA; serial 0601773716
Condenser is Model GSH130421; serial 0605212296
A General Model AC-3 air cleaner and activated carbon air purifier is also part of the system, on the furnace side of the system.
The return duct from the hall back to the system in the crawlspace is 18” flex duct. The main supply duct is 16” hard pipe. There are 10 4x12 and two 6x12 supply registers. The supply ducts to the registers are 6" flex, except for the two larger registers, which have 8" flex ducts.
The Noises
While here, the Rep checked and corrected the DIP switch settings on the main circuit board in the furnace.
He changed the settings to: 1-on, 2-on, 3-off, 4-off, 5-on, 6-on, 7-on, 8-off.
The main effect of these changes that I notice is that the blower is now pushing/pulling a lot more air through the system, especially in heat pump heat mode. This is causing two kinds of noise at the return in the hall: the grille ‘sings’ and there is a rumbling sound in the plenum behind the grille.
The Grille
I turned the grille upside down. That reduced the singing a little, but it’s still audible in nearby rooms. The grille is an odd size (22” by 26”) so I haven’t been able to find a replacement, ‘high volume’ grille. Any suggestions?
The Choke Point
The rumbling sound is coming from a “choke point” in the return plenum, where the plenum goes through the floor. This is the only old part of the duct system. The original installer probably should have enlarged the plenum there. Instead, when we complained about the noises, he set the blower to a lower setting.
I’m not sure whether I should try to get the choke point enlarged. Are the rumbling and the choke point likely to cause maintenance or reliability problems with the system?
Noises (singing and rumble) at main return grille-full-crawlspace-system.jpg   Noises (singing and rumble) at main return grille-return-plenum-front-back.jpg   Noises (singing and rumble) at main return grille-return-plenum-hall-closet.jpg   Noises (singing and rumble) at main return grille-grille.jpg   Noises (singing and rumble) at main return grille-choke-point.jpg
Noises (singing and rumble) at main return grille-return-plenum-box-crawlspace-1.jpg
John_W is offline   Reply With Quote
Old 01-28-2010, 05:40 PM   #2
For the grill you can get the needle nose pliers out and change the fin angle to more horizontal. Works most of the time but not always.
Ask your goodman guy how many CFM he has set up for the heat pump. Should be 1200 with that unit to get full BTU output with the correct refrigerant charge.
