Noise When A/C Cycles On - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-09-2013, 07:43 AM   #16
Rewards Points: 6,652
Raylo, one thing I found out, the DAP foam in a can, which is water based, actually reacts with Copper, where as Big Stuff does not. We had thought that with the DAP being more flexible, it would work better, but in turn, it started to cause corrosion within a day, so had to clean it off as best as we could, and then use Big Stuff.
I found just moving a couple of brackets, and moving the lineset in one spot, quieted down mine a lot, so that I did not hear as much harmonic, when the R-22 was flowing.
Old 08-09-2013, 08:26 AM   #17
Still Decompressing
Rewards Points: 273
We purchased the home towards the end of last year. The house was built in the mid 90's. The AC unit could be original to the house.
I will check the lined at the ext wall.
Thanks for the input.
caveeagle is offline   Reply With Quote
Old 08-09-2013, 08:31 AM   #18
Rewards Points: 256
Mine made a very loud "brrrr" noise at startup and I just oiled the motor on the compressor outside: problem solved.
michaelcherr is offline   Reply With Quote
Old 08-09-2013, 08:55 AM   #19
Still Decompressing
Rewards Points: 273
Are you talking about the condensor fan motor?
Old 08-09-2013, 08:58 AM   #20
Rewards Points: 256
.Yes.
Old 08-09-2013, 09:01 AM   #21
Still Decompressing
Rewards Points: 273
special kind of oil?? What was it?
Old 08-13-2013, 09:19 AM   #22
Rewards Points: 256
I think I used 3 in 1 oil.
Old 08-13-2013, 09:25 AM   #23
Rewards Points: 1,668
SeniorSitizen is offline   Reply With Quote
Furnace cycles multiple times Tom the elder HVAC 17 12-30-2012 04:23 PM
Rattling Noise from Roof when windy drgillian Roofing/Siding 3 02-18-2011 09:05 AM
can you help me with this really odd noise? tuffluck Electrical 15 01-10-2011 05:35 PM
Frigidaire freezer noise (sounds like a compressor) onelove Appliances 3 10-09-2010 09:16 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
