Old 01-28-2007, 05:14 PM   #1
No Temperature Change
It seems like my furnace is coming on even when it is at the temperature is where it is supposed to be. For example, if I set my thermostat for 68, the heater will kick on even though the temp hasn't dropped to 67. Could my thermostat be bad?
rightsidedown is offline   Reply With Quote
Old 01-28-2007, 07:45 PM   #2
Thoroughbred Mopar Man
Hi rightsidedown
It sounds like your thermostat is digital and doing exactly what it was told to do. If you go into the software in the thermostat you should be able to set your deadband or otherwise know as temperature differential. Most digital thermostats come from the factory set at 1 deg. deadband, offset or temperature differential. Hope this helps.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 01-28-2007, 10:20 PM   #3
Thanks Carrierman for your help. Let me make sure I understand what you are saying...digital thermostats are designed not to go off the set temperature? Or will it go to 67 then turn on the heat?
Old 01-30-2007, 08:09 PM   #4
Electrical Engineer
Digital thermostats are very precise and if your furnace is sized correctly it will not go off the set temperature. This is good.
rakes9720 is offline   Reply With Quote
Temperature Differance Over Coil rjordan392 HVAC 9 08-11-2007 06:34 PM
Considering Room Addition & Roof Change pkthomas_ar Building & Construction 4 05-02-2007 07:41 PM
Is there a way to circulate the outside temperature (air) into my home & take out hot 915855 Building & Construction 6 10-14-2006 04:19 PM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 07:54 PM
