No Spark - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 12:10 PM   #1
No spark
Hey everyone. I've got an armstrong hvac unit blowing cold air. It seems to be my Fenwal automatic ignition system is not providing spark from the plug to the ignitor. Does the whole module have to be replaced or could it be something else? I'd hate to run out and buy the part if that's not the problem. PLEASE HELP
chris cairns is offline   Reply With Quote
Old 12-12-2010, 12:16 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
Post a pic of it and the front of the furnace and burners. Is it getting a 24 volt signal to tell it to spark? If so the whole module needs replacing. I am not totally familiar with your unit so don't ask me how to find the signal. Would need the wiring diagram to help more.
Old 12-12-2010, 12:23 PM   #3
Thanx Yuri. I put a meter on the spark plug and got no reading...no juice. I'm leaning toward replacement
Old 12-12-2010, 12:55 PM   #4
Hvac Pro
yuri's Avatar
It should have 2 wires to it from the control board telling it when to produce the spark.
Old 12-12-2010, 03:15 PM   #5
when you do a call for heat does the blower motor turn on and blow cold air? if so then you have a safety switch out. and with a safety switch tripped its not going to try to spark.
hvac kid is offline   Reply With Quote
Outlet Spark DIYLI Electrical 13 06-16-2012 10:08 AM
Pop and Spark daveofnj Electrical 2 11-11-2010 07:35 PM
big spark from hot feeder when install a water heater maittai1 Electrical 2 08-08-2010 10:28 PM
Occasional Spark At Outlets jte1130 Electrical 12 11-25-2009 12:20 PM
HDMI makes huge spark!!! cwcox2 Electrical 17 12-15-2008 09:18 PM
