Old 06-27-2012, 08:47 PM   #16
An old Tradesmen
no response from fan, central air or furnace
Connect the red wire from the thermostat directly to the R terminal of the board.
Old 06-27-2012, 11:27 PM   #17
All is good!! Prior to seeing your response I noticed the red wire was not going directly to the board but twisted to another red wire and exiting the furnace area. Well it went to the flotech something or another.... The damn thing was unplugged and must stop the current loop back to the board!
Good grief what a relief. Old Stat is back in place and the board was probably not needed. $85 later and hours of messing around its good.
Thank you all for your guidance and patience. Sometimes it's the simple things
NickMN is offline   Reply With Quote
The Following User Says Thank You to NickMN For This Useful Post:
Doc Holliday (06-27-2012)
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Central Air Furnace blower moter Joe Hobson HVAC 1 11-10-2011 12:10 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
