No Power To Units - HVAC - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 05:12 AM   #1
No power to units
My wife woke me up tonight because it was getting hot in our house. I went downstairs to see if I could figure anything out with my limited knowledge. It seems as though there is no power to furnace. I checked the breaker and tried flipping the power switch next to the unit and nothing. We had the furnace replaced about 8 years ago. It is a Goodman unit, not sure of the model number. We have had a few issues in the past, and I remember the tech showing me the indicator light inside the unit for diagnostics. It isn't on. Any deas on where I can begin?
shoyer is offline   Reply With Quote
Old 09-01-2010, 06:25 AM   #2
Control Tranformer may be fused or with a reset button on it. if not see if you have 24v coming out. Goodman also, if I recall has a car like two blade fuse in the control board.
lamon2524 is offline   Reply With Quote
Old 09-01-2010, 07:26 AM   #3
I went and checked the voltage at the transformer. 122v in and 27v out, so that appears to be ok. I did pull the 3 amp fuse on the board and it appears to be burnt. I will get one while I am out this AM and see if that works. Thanks for the help in getting me started!
Old 09-01-2010, 07:31 AM   #4
Glad to help, love easy service calls.
Old 09-01-2010, 09:28 AM   #5
It worked! Amazing how a simple 3 amp fuse can bring down the whole ship. Thanks for your help lamon! It is greatly appreciated!
Old 09-01-2010, 12:27 PM   #6
I don't want to "rain or your parade", but blown fuses often indicate an issue that needs further investigation.
If your new fuse blows then you better trace the LV circuits for further problems. (wiring or downstream components).
hennyh is offline   Reply With Quote
Old 09-01-2010, 06:31 PM   #7
An old Tradesmen
Rewards Points: 6,066
Yep. They don't blow because everything is ok.
So you got a problem some where.
Old 09-04-2010, 10:25 AM   #8
So far so good with the fuse. I will definetly keep an eye on it. We had a ton of lighting move thru the night it went out, so I'm thinking that might of had something to do with it. But again, I will continue to check on it. Thanks for all of the help!
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 08:45 PM
Power tool Junkie Question UpComingBuilder Tools 3 10-05-2009 10:24 AM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 08:26 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
