-   -   No Power to Thermostat (http://www.diychatroom.com/f17/no-power-thermostat-33700/)
Vito 12-13-2008 10:34 PM
Okay I need to know what to do next. This morning I woke up to fine our digital thermostat does not have power. The circuit breakers check fine. I have two identical thermostats, so I changed them. After the switch in confirmed it is not a thermostat issue, so I am trying to figure out why I am not getting power. The wiring looks good at the thermostat. There are no loose wires outside at the compressor or inside in the air handler. Any ideas as to what I may do next?
TazinCR 12-13-2008 11:00 PM
Check the transformer that feeds the thermostats. If they have battery backup the batteries are bad. Still need to fix transformers.
Vito 12-13-2008 11:18 PM
Where are the transformers generally located. I did not readily see a transformer near the air handler or compressor. Does the transformer look similar to what is used for a doorbell transformer?
beenthere 12-14-2008 06:58 AM
It is in the air handler.
It may be good, and the low voltage fuse may have blown.
Meaning you have a short, that needs to be found and repaired.
Vito 12-14-2008 07:07 AM
I did see a five volt fuse in the air handler that was okay last night. Would that be the fuse to which you are referring? If that is okay then maybe I am not experiencing a short.
I guess I will pull the panel off again and find the transformer to check it out.
beenthere 12-14-2008 07:26 AM
That would be the fuse.
Its probably 5 amp, not volt.
Vito 12-14-2008 04:24 PM
Sorry about that yes, it is a 5 amp fuse and it is good.
I did check and both sides of the 120 and both did register 120. However the 24 volt side showed absolutely nothing.
I have a two story so I checked the other air handler and it was showing the the two 120 and the 24 volt on the other side. It does look like the transformer is at least not working.
I will have to pick one up tomorrow when there is a supply house available.
Could there be any other issues?
beenthere 12-14-2008 05:04 PM
Need to check what caused the transformer to burn out.
You don't want to install a new one, and watch it smoke.
Vito 12-14-2008 07:24 PM
Exactly I do not want to install it and watch it fry, but I am at a loss as to what to check at this point.
beenthere 12-14-2008 09:51 PM
All teh low voltage wires for shorts, and the low voltage componets.
