No Power To My Furnace. Can't Diagnose. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-30-2014, 09:08 PM   #16
Rewards Points: 225
Check your T-stat wire running out to your condenser... You may have bare wire showing or grounding out on something... This would also blow your fuse.
a.man1302 is offline   Reply With Quote
Old 07-30-2014, 09:24 PM   #17
An old Tradesmen
Rewards Points: 6,598
If you mean 15 amp fuse, in that fuse box. Then water may have gotten into the blower motor, and be shorting out the motor.
Old 07-30-2014, 11:01 PM   #18
Yes, I meant 'amp'. My brain is fried at this point, and a somewhat foreign terminology seems to have been one of the first victims.
To your comment though, it seems to me that the water was a symptom of the furnace shutdown, rather than the cause. I'm not sure at this point how to explain/justify that though really. I did not find signs of water in the blower housing, but around the outside. Besides the floor, the only signs of liquid were practically directly above the furnace switch, though I did not find signs of it in/on the switch box.
I will check the thermostat wires in the morning for signs of short. Thanks again, guys. I'll update tomorrow.
Besolondon is offline   Reply With Quote
Old 07-30-2014, 11:16 PM   #19
Rewards Points: 242
The 16 volt transformer is for a doorbell
hvac instructor is offline   Reply With Quote
Should my furnace closet have a huge duct opening into the vented attic? iLikeDirt HVAC 9 04-27-2014 08:13 PM
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 21 03-25-2013 02:14 PM
Power strip hack salex Electrical 3 01-31-2012 07:10 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
